<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can&#x27;t launch electron-m5burner-v2-eletron on macOS Catalina (10.15.5)]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I just downloaded M5Burner v2 from <a href="https://m5stack.com/pages/download" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.com/pages/download</a>, unzipped, and tried to launch. However, I got an error message like 'The application "electron-m5burner-v2-eletron" can't be opened'. I also tried unzipping with The Unarchiver and could open the app, then got error messages as follows (an excerpt).</p>
<p dir="auto">Application Specific Information:<br />
dyld: launch, loading dependent libraries</p>
<p dir="auto">Dyld Error Message:<br />
Library not loaded: @rpath/Electron Framework.framework/Electron Framework<br />
Referenced from: /Applications/electron-m5burner-v2-eletron.app/Contents/MacOS/electron-m5burner-v2-eletron<br />
Reason: no suitable image found.  Did find:<br />
/Applications/electron-m5burner-v2-eletron.app/Contents/MacOS/../Frameworks/Electron Framework.framework/Electron Framework: file too short<br />
/Applications/electron-m5burner-v2-eletron.app/Contents/MacOS/../Frameworks/Electron Framework.framework/Electron Framework: stat() failed with errno=1</p>
<p dir="auto">M5Burner v1.0.1 has been working fine in the same environment. Could you please let me know if you know anything about this issue.</p>
<p dir="auto">BTW, I found an article that seems to be related to this issue. <a href="https://medium.com/cacher-app/getting-your-electron-app-working-on-macos-catalina-10-15-63e53f397da2" target="_blank" rel="noopener noreferrer nofollow ugc">https://medium.com/cacher-app/getting-your-electron-app-working-on-macos-catalina-10-15-63e53f397da2</a></p>
<p dir="auto">Thanks,<br />
Shigeru</p>
]]></description><link>https://community.m5stack.com/topic/2018/can-t-launch-electron-m5burner-v2-eletron-on-macos-catalina-10-15-5</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:06:16 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2018.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 06 Jun 2020 23:16:36 GMT</pubDate><ttl>60</ttl></channel></rss>
