<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickC and ENV II Unit?(SOLVED)]]></title><description><![CDATA[<p dir="auto">I realize that the ENV hat is available, but it won't work for my purposes which require that the stick and temperature probe be in different locations. Right now, I have a solution that's working fine with the original ENV unit. But when I attempt to change to ENV II in UIFlow, it shows this unit as not working with the M5StickC.</p>
<p dir="auto">Considering the unavailable of the original ENV unit, am I simply out of luck? Or is this a matter of waiting for a UIFlow update?</p>
]]></description><link>https://community.m5stack.com/topic/2023/m5stickc-and-env-ii-unit-solved</link><generator>RSS for Node</generator><lastBuildDate>Mon, 04 May 2026 17:15:11 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2023.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Jun 2020 14:27:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickC and ENV II Unit?(SOLVED) on Mon, 08 Jun 2020 17:09:43 GMT]]></title><description><![CDATA[<p dir="auto">It seems I've answered my own question. By switching over to the "beta" version of UIFlow, it appears that ENV II is available, so will be supported in upcoming versions.</p>
<p dir="auto">Mark it closed!</p>
]]></description><link>https://community.m5stack.com/post/8933</link><guid isPermaLink="true">https://community.m5stack.com/post/8933</guid><dc:creator><![CDATA[Devilstower]]></dc:creator><pubDate>Mon, 08 Jun 2020 17:09:43 GMT</pubDate></item></channel></rss>
