<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I think my StickC has died ... any suggestions?]]></title><description><![CDATA[<p dir="auto">Since arriving a couple of weeks ago, the M5StickC has worked like a champ. Together with the ENV and weight sensors, it's proven to be perfect for a project that was in the works and (except for some issues around swapping networks) has performed like a champ. I've had the StickC connected to a small (2600mah) power bank which was in turn connected with a small (2w) solar panel. The combination had it running for days, recording data and sending it along to Thingspeak.</p>
<p dir="auto">But last night I disconnected the StickC to make some code changes. It tested out just fine, but when I went to power it up this morning ... it wouldn't start. Not when connected to the battery, not when connected to the PC, not when connected to a USB power source. I've tried all the familiar long press and left+right options that have helped with past issues, but the screen is stubbornly dark.</p>
<p dir="auto">Is there something I'm overlooking? Anything else I can try to revive a StickC that seems to be ... Sick-C?</p>
]]></description><link>https://community.m5stack.com/topic/2028/i-think-my-stickc-has-died-any-suggestions</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 20:41:30 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2028.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Jun 2020 17:59:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I think my StickC has died ... any suggestions? on Thu, 02 Jul 2020 00:49:23 GMT]]></title><description><![CDATA[<p dir="auto">You can try to reset your 'sick-C' by erase your flash and burn the firmware again?<br />
(my older m5stickC bought at 2017 .it never 'died'. I erase and burn the firmware for about 1,500 times and it never 'sicked')</p>
]]></description><link>https://community.m5stack.com/post/9218</link><guid isPermaLink="true">https://community.m5stack.com/post/9218</guid><dc:creator><![CDATA[sysdl132]]></dc:creator><pubDate>Thu, 02 Jul 2020 00:49:23 GMT</pubDate></item><item><title><![CDATA[Reply to I think my StickC has died ... any suggestions? on Wed, 01 Jul 2020 08:32:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/devilstower" aria-label="Profile: devilstower">@<bdi>devilstower</bdi></a> you could try to upload the FactoryTest then check the serial log.  if log normal and the screen still dark.  you could contact the store.</p>
]]></description><link>https://community.m5stack.com/post/9212</link><guid isPermaLink="true">https://community.m5stack.com/post/9212</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 01 Jul 2020 08:32:44 GMT</pubDate></item><item><title><![CDATA[Reply to I think my StickC has died ... any suggestions? on Tue, 30 Jun 2020 13:19:04 GMT]]></title><description><![CDATA[<p dir="auto">I had put this StickC aside to work with another (I have a dozen or so of them). And then I ran into the same thing about ten StickC's later.</p>
<p dir="auto">With both of these, it seems to be a screen failure. I can download a program, get the LED to flash, and even connect via network. But the screen remains dead -- even if I just run the burner and start the device over from scratch. I've also tried shorting BAT to GND, just in case, and get the same results. Another 8 StickC's working dandy (I was making a batch of prototype devices) but these two appear to have simply lost their screens.</p>
<p dir="auto">So it's not really dead. It's just gone dark.</p>
]]></description><link>https://community.m5stack.com/post/9200</link><guid isPermaLink="true">https://community.m5stack.com/post/9200</guid><dc:creator><![CDATA[Devilstower]]></dc:creator><pubDate>Tue, 30 Jun 2020 13:19:04 GMT</pubDate></item><item><title><![CDATA[Reply to I think my StickC has died ... any suggestions? on Mon, 15 Jun 2020 10:01:16 GMT]]></title><description><![CDATA[<p dir="auto">you could try following operations: 1. Short the BAT to GND，disconnect the short circuit after 2 seconds . 2. Insert the USB cable. 3. After the screen is lit, USB continues to charge the device.</p>
<p dir="auto">if still not working .  pls contact the store.</p>
]]></description><link>https://community.m5stack.com/post/9009</link><guid isPermaLink="true">https://community.m5stack.com/post/9009</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 15 Jun 2020 10:01:16 GMT</pubDate></item><item><title><![CDATA[Reply to I think my StickC has died ... any suggestions? on Sat, 13 Jun 2020 13:52:05 GMT]]></title><description><![CDATA[<p dir="auto">I Find just leaving it plugged into a charger for a couple hours works as I keep letting batteries go flat.</p>
]]></description><link>https://community.m5stack.com/post/8988</link><guid isPermaLink="true">https://community.m5stack.com/post/8988</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 13 Jun 2020 13:52:05 GMT</pubDate></item><item><title><![CDATA[Reply to I think my StickC has died ... any suggestions? on Sat, 13 Jun 2020 12:55:21 GMT]]></title><description><![CDATA[<p dir="auto">When you connect to the PC does it detect a device? Hopefully it's just the screen that blew.</p>
]]></description><link>https://community.m5stack.com/post/8987</link><guid isPermaLink="true">https://community.m5stack.com/post/8987</guid><dc:creator><![CDATA[jhfoo]]></dc:creator><pubDate>Sat, 13 Jun 2020 12:55:21 GMT</pubDate></item></channel></rss>
