<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack after loading the program is still restarting.]]></title><description><![CDATA[<p dir="auto">I have M5Stack.<br />
When I compile my program for Arduino 1.8.12, windows 7 32 bit and I do download with G0 = gnd with a speed of 115200, the program restarts in a circle.<br />
Other speeds don't work.<br />
below the log from the terminal</p>
<p dir="auto">rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)<br />
mode:DIO, clock div:1<br />
load:0x3fff0018,len:4<br />
load:0x3fff001c,len:1216<br />
ho 0 tail 12 room 4<br />
load:0x40078000,len:9720<br />
load:0x40080400,len:6352<br />
entry 0x400806b8</p>
<p dir="auto">M5Stack initializing...&lt;0&gt;&lt;0&gt;&lt;0&gt;&lt;0&gt;&lt;0&gt;&lt;0&gt;&lt;0&gt;&lt;0&gt;&lt;0&gt;<br />
Booting device...<br />
Reading settings from eeprom.<br />
Settings not found. Initialization.<br />
Settings saved to eeprom.<br />
Init TFT display<br />
merged:6101FFF8000009285A3B0648030000B4179D763404080805000000<br />
merged:62B002E0000000FFB400330B0000000000000000<br />
Start BLE with PIN auth<br />
ets Jun  8 2016 00:22:57</p>
<p dir="auto">rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)<br />
merged:6101FFF8000009285A3B0648030000B4179D763404080805000000.........</p>
]]></description><link>https://community.m5stack.com/topic/2052/m5stack-after-loading-the-program-is-still-restarting</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 01:44:53 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2052.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Jun 2020 13:14:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack after loading the program is still restarting. on Sat, 20 Jun 2020 15:28:47 GMT]]></title><description><![CDATA[<p dir="auto">Problem has been solved<br />
The weak USB cable was to blame, after replacing the cable with the original Samsung, the problem did not return.<br />
Problem messages are:<br />
"BrownOut detector was triggered" and<br />
"The Guru Meditation" something like Blue screen of Death (BSOD)</p>
]]></description><link>https://community.m5stack.com/post/9068</link><guid isPermaLink="true">https://community.m5stack.com/post/9068</guid><dc:creator><![CDATA[spairo]]></dc:creator><pubDate>Sat, 20 Jun 2020 15:28:47 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack after loading the program is still restarting. on Fri, 19 Jun 2020 15:22:57 GMT]]></title><description><![CDATA[<p dir="auto">after download m5stack-ble  black box is resrating in loop with register dump.</p>
<p dir="auto">Rebooting...<br />
entry 0x400806b8<br />
M5Stack initializing...OK<br />
Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.<br />
Core 0 register dump:<br />
PC      : 0x4010512d  PS      : 0x00050031  A0      : 0x4008565c  A1      : 0x3ffbe360<br />
A2      : 0x00000000  A3      : 0x3ff48044  A4      : 0x800e04be  A5      : 0x400916e8<br />
A6      : 0x00000000  A7      : 0x40085fb0  A8      : 0x00000000  A9      : 0x3ffbb700<br />
A10     : 0x00000000  A11     : 0x3ffbbd60  A12     : 0x800e04b3  A13     : 0x3ffbc010<br />
A14     : 0x00000000  A15     : 0x3ffbc03f  SAR     : 0x00000016  EXCCAUSE: 0x0000001c<br />
EXCVADDR: 0x00000000  LBEG    : 0x00000000  LEND    : 0x00000000  LCOUNT  : 0x00000000<br />
Core 0 was running in ISR context:<br />
EPC1    : 0x4010512d  EPC2    : 0x00000000  EPC3    : 0x00000000  EPC4    : 0x00000000</p>
<p dir="auto">Backtrace: 0x4010512d:0x3ffbe360 0x40085659:0x3ffbe380 0x40185037:0x3ffbc060 0x400e1a02:0x3ffbc080 0x40090745:0x3ffbc0a0 0x4008ef51:0x3ffbc0c0</p>
]]></description><link>https://community.m5stack.com/post/9053</link><guid isPermaLink="true">https://community.m5stack.com/post/9053</guid><dc:creator><![CDATA[spairo]]></dc:creator><pubDate>Fri, 19 Jun 2020 15:22:57 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack after loading the program is still restarting. on Fri, 19 Jun 2020 11:34:05 GMT]]></title><description><![CDATA[<p dir="auto">I have m5Stack, a small black box with three silver keys and a TFT LCD display.<br />
I can't load anything into m5sstack if I don't give G0 then GND.<br />
I use 7 Pro x32 Win and I use Arduino 1.8.8 or 1.812.<br />
I don't know any other way to program m5Stack under Windows</p>
]]></description><link>https://community.m5stack.com/post/9049</link><guid isPermaLink="true">https://community.m5stack.com/post/9049</guid><dc:creator><![CDATA[spairo]]></dc:creator><pubDate>Fri, 19 Jun 2020 11:34:05 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack after loading the program is still restarting. on Fri, 19 Jun 2020 08:18:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spairo" aria-label="Profile: spairo">@<bdi>spairo</bdi></a> why you connect the G0 --&gt;  GND ？and which device are you use?  M5Stack download program don't need G0--&gt;GND.   it differ other dev board</p>
]]></description><link>https://community.m5stack.com/post/9046</link><guid isPermaLink="true">https://community.m5stack.com/post/9046</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 19 Jun 2020 08:18:33 GMT</pubDate></item></channel></rss>
