<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cant run M5Burner in Linux]]></title><description><![CDATA[<p dir="auto">I cant start the new M5Burner on Ubuntu 18.04.4 LTS. I get a JavaScript error:<br />
GLIBC_2.28 not found<br />
Please help.</p>
]]></description><link>https://community.m5stack.com/topic/2073/cant-run-m5burner-in-linux</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 01:04:07 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2073.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 24 Jun 2020 09:10:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cant run M5Burner in Linux on Thu, 09 Jul 2020 23:55:44 GMT]]></title><description><![CDATA[<p dir="auto">Works great. Thank you so much :)</p>
]]></description><link>https://community.m5stack.com/post/9290</link><guid isPermaLink="true">https://community.m5stack.com/post/9290</guid><dc:creator><![CDATA[xis]]></dc:creator><pubDate>Thu, 09 Jul 2020 23:55:44 GMT</pubDate></item><item><title><![CDATA[Reply to Cant run M5Burner in Linux on Thu, 09 Jul 2020 10:39:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xis" aria-label="Profile: xis">@<bdi>xis</bdi></a>  the software has been updated.  you could download a new one, then try it again.</p>
]]></description><link>https://community.m5stack.com/post/9282</link><guid isPermaLink="true">https://community.m5stack.com/post/9282</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 09 Jul 2020 10:39:11 GMT</pubDate></item><item><title><![CDATA[Reply to Cant run M5Burner in Linux on Wed, 08 Jul 2020 18:24:09 GMT]]></title><description><![CDATA[<h1>Connecting........__<em><strong>.....</strong></em><br />
Detecting chip type...<br />
A fatal error occurred: Timed out waiting for packet header</h1>
<h1>Erase Failed</h1>
<p dir="auto">That is using 750000 baud rate.<br />
User is on the dialout group.<br />
Arduino IDE works. And also the last version of M5Burner used to work.</p>
]]></description><link>https://community.m5stack.com/post/9279</link><guid isPermaLink="true">https://community.m5stack.com/post/9279</guid><dc:creator><![CDATA[xis]]></dc:creator><pubDate>Wed, 08 Jul 2020 18:24:09 GMT</pubDate></item><item><title><![CDATA[Reply to Cant run M5Burner in Linux on Wed, 08 Jul 2020 07:18:03 GMT]]></title><description><![CDATA[<p dir="auto">Which baud rate did you use? for M5stickC and M5atom you should use baud rate 750000, make sure the correct serial port is selected and that you have erased the device before flashing.</p>
<p dir="auto">Edit - also not sure if you already know this but using esp32 devices on linux you need to add the current user to the dialout group in order to access the port that the device is connected to. Open up a terminal and enter these commands</p>
<pre><code>Sudo usermod -a -G dialout $user
Sudo chmod a+rw /dev/ttyUSB0
]]></description><link>https://community.m5stack.com/post/9264</link><guid isPermaLink="true">https://community.m5stack.com/post/9264</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Wed, 08 Jul 2020 07:18:03 GMT</pubDate></item><item><title><![CDATA[Reply to Cant run M5Burner in Linux on Tue, 07 Jul 2020 17:42:54 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for the help.<br />
So, using uiflow desktop ide  there is another error:</p>
<p dir="auto">Chip is ESP32-PICO-D4 (revision 1)<br />
Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, VRef calibration in efuse<br />
MAC: d8:a0:1d:56:b9:b8<br />
Uploading stub...</p>
<h1>A fatal error occurred: Timed out waiting for packet header</h1>
<h1>Burn Failed</h1>
<p dir="auto">How can I update GlibC to 2.28?</p>
]]></description><link>https://community.m5stack.com/post/9260</link><guid isPermaLink="true">https://community.m5stack.com/post/9260</guid><dc:creator><![CDATA[xis]]></dc:creator><pubDate>Tue, 07 Jul 2020 17:42:54 GMT</pubDate></item><item><title><![CDATA[Reply to Cant run M5Burner in Linux on Sun, 28 Jun 2020 01:48:39 GMT]]></title><description><![CDATA[<p dir="auto">thank you feedback. we will fix this problem as soon as possible</p>
]]></description><link>https://community.m5stack.com/post/9170</link><guid isPermaLink="true">https://community.m5stack.com/post/9170</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Sun, 28 Jun 2020 01:48:39 GMT</pubDate></item><item><title><![CDATA[Reply to Cant run M5Burner in Linux on Fri, 26 Jun 2020 16:01:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xis" aria-label="Profile: xis">@<bdi>xis</bdi></a> said in <a href="/post/9128">Cant run M5Burner in Linux</a>:</p>
Please help.</p>
<p dir="auto">Have you updated GlibC to 2.28?</p>
]]></description><link>https://community.m5stack.com/post/9163</link><guid isPermaLink="true">https://community.m5stack.com/post/9163</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 26 Jun 2020 16:01:19 GMT</pubDate></item><item><title><![CDATA[Reply to Cant run M5Burner in Linux on Thu, 25 Jun 2020 04:53:34 GMT]]></title><description><![CDATA[<p dir="auto">Are you using standalone burner or firmware burner within uiflow desktop ide? I suggest you use the latter, I had no issues flashing devices this way on ubuntu 18</p>
]]></description><link>https://community.m5stack.com/post/9145</link><guid isPermaLink="true">https://community.m5stack.com/post/9145</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Thu, 25 Jun 2020 04:53:34 GMT</pubDate></item></channel></rss>
