<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[upload via USB from the desktop-Version of UI-Flow]]></title><description><![CDATA[<p dir="auto">I would like to use the Desktop Version of UI-Flow.<br />
But I can't get a connection via USB.<br />
I have installed the USB-Driver several times.<br />
M5-Burner does work well.<br />
The Online-Version of UI-Flow is working pretty well but I would like the m5Stick in my lessons, where we have very limitted access to the WiFi-Settings.</p>
]]></description><link>https://community.m5stack.com/topic/2088/upload-via-usb-from-the-desktop-version-of-ui-flow</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 05:06:51 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2088.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 01 Jul 2020 11:10:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to upload via USB from the desktop-Version of UI-Flow on Sun, 05 Jul 2020 12:46:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus" aria-label="Profile: lukasmaximus">@<bdi>lukasmaximus</bdi></a><br />
Thank you, that helped</p>
]]></description><link>https://community.m5stack.com/post/9244</link><guid isPermaLink="true">https://community.m5stack.com/post/9244</guid><dc:creator><![CDATA[JhonnyTank]]></dc:creator><pubDate>Sun, 05 Jul 2020 12:46:41 GMT</pubDate></item><item><title><![CDATA[Reply to upload via USB from the desktop-Version of UI-Flow on Sun, 05 Jul 2020 06:59:49 GMT]]></title><description><![CDATA[<p dir="auto">Which M5Stack device are you using? each device has a different method of getting into usb mode which you have to set on the device itself first. You can check this video for how to set it for each device <a href="https://youtu.be/MTCjKhVKOto?t=302" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/MTCjKhVKOto?t=302</a></p>
]]></description><link>https://community.m5stack.com/post/9241</link><guid isPermaLink="true">https://community.m5stack.com/post/9241</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Sun, 05 Jul 2020 06:59:49 GMT</pubDate></item><item><title><![CDATA[Reply to upload via USB from the desktop-Version of UI-Flow on Fri, 03 Jul 2020 10:51:09 GMT]]></title><description><![CDATA[<p dir="auto">Sorry the Tutorial is a little bit missleading.<br />
I am using Firmware 1.5.4 and I am not able to find any option for usb Mode.<br />
The USB-Driver is working fine, because m5-Burner is able to flash the device.</p>
]]></description><link>https://community.m5stack.com/post/9233</link><guid isPermaLink="true">https://community.m5stack.com/post/9233</guid><dc:creator><![CDATA[JhonnyTank]]></dc:creator><pubDate>Fri, 03 Jul 2020 10:51:09 GMT</pubDate></item><item><title><![CDATA[Reply to upload via USB from the desktop-Version of UI-Flow on Fri, 03 Jul 2020 08:34:01 GMT]]></title><description><![CDATA[<p dir="auto">you need setup the device to the USB mode before you connect to the Desktop IDE</p>
<p dir="auto">more information you could refer this tutorial:</p>
<p dir="auto"><a href="https://docs.m5stack.com/#/en/quick_start/m5stickc/m5stickc_quick_start_with_uiflow" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/quick_start/m5stickc/m5stickc_quick_start_with_uiflow</a></p>
]]></description><link>https://community.m5stack.com/post/9230</link><guid isPermaLink="true">https://community.m5stack.com/post/9230</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 03 Jul 2020 08:34:01 GMT</pubDate></item></channel></rss>
