<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[FactoryTest.ino fails to compile from new Arduino Installation and W10, others ok]]></title><description><![CDATA[<p dir="auto">Other examples compile ok, except the factorytest with all new installation.... from the zip backup.</p>
<p dir="auto">Library problem.....<br />
Any suggestions, idea, to help and recompile the good factorytest.ino example ...</p>
<p dir="auto">Waiting for your support and have a good day...<br />
Best regards<br />
Jp</p>
]]></description><link>https://community.m5stack.com/topic/210/factorytest-ino-fails-to-compile-from-new-arduino-installation-and-w10-others-ok</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:01:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/210.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 16 May 2018 10:12:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to FactoryTest.ino fails to compile from new Arduino Installation and W10, others ok on Fri, 18 May 2018 11:16:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jp" aria-label="Profile: jp">@<bdi>jp</bdi></a> No problem JP !!</p>
]]></description><link>https://community.m5stack.com/post/994</link><guid isPermaLink="true">https://community.m5stack.com/post/994</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Fri, 18 May 2018 11:16:22 GMT</pubDate></item><item><title><![CDATA[Reply to FactoryTest.ino fails to compile from new Arduino Installation and W10, others ok on Fri, 18 May 2018 09:56:17 GMT]]></title><description><![CDATA[<p dir="auto">Great thanks..You are right : add the zip Library fails, and cause my problems.<br />
As you suggest with Include ..<br />
It compiles now ok.<br />
THANKS<br />
Jp</p>
]]></description><link>https://community.m5stack.com/post/993</link><guid isPermaLink="true">https://community.m5stack.com/post/993</guid><dc:creator><![CDATA[Jp]]></dc:creator><pubDate>Fri, 18 May 2018 09:56:17 GMT</pubDate></item><item><title><![CDATA[Reply to FactoryTest.ino fails to compile from new Arduino Installation and W10, others ok on Thu, 17 May 2018 13:52:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jp" aria-label="Profile: jp">@<bdi>jp</bdi></a> Hi JP,</p>
<p dir="auto">I just tested flashing FactoryTest... Im running the latest m5stack library version 0.1.9</p>
<p dir="auto">It worked fine for me....</p>
<p dir="auto">I had previously updated the M5Stack library to 0.1.9 via Arduino menu - Sketch / Include Libraries / Manage Libraries</p>
<p dir="auto">I loaded FactoryTest from the list of examples for the M5Stack.  So from the Arduino menu that would be:  File / Examples / M5Stack / Basics / FactoryTest</p>
<p dir="auto">Perhaps try loading it that way rather than via -  Add .ZIP Libraries</p>
<p dir="auto">I am sure I read something a while ago that suggested that loading using the ZIP files can cause issues under certain circumstances.</p>
]]></description><link>https://community.m5stack.com/post/988</link><guid isPermaLink="true">https://community.m5stack.com/post/988</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Thu, 17 May 2018 13:52:31 GMT</pubDate></item></channel></rss>
