<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[EXTEND IO Unit - is anyone successfully using this unit?  If so, please help!]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I have now unsuccessfully tried 3 different Extend IO units (2 arrived today from different suppliers) on 3 different M5Stacks (Fire and Gray).  I have also tried the units via a Pa.Hub but they still give an error.<br />
Other units, eg Temp, PIR have worked OK.</p>
<p dir="auto">It would be great to know if anyone is successfully using these units before I spend more time on this method of getting more IO onto the M5Stack.</p>
<p dir="auto">I have used Blockly V1.5.4 and 1.4.5 to write simple test routines.</p>
<p dir="auto">Errors on M5Stack display:</p>
<p dir="auto">"ERROR<br />
local variable referenced before assignment"</p>
<p dir="auto">or</p>
<p dir="auto">"Unit: Ext IO unit may not be connected"</p>
<p dir="auto">Any help or advice would be welcomed.</p>
]]></description><link>https://community.m5stack.com/topic/2111/extend-io-unit-is-anyone-successfully-using-this-unit-if-so-please-help</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 15:21:17 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2111.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 08 Jul 2020 17:05:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to EXTEND IO Unit - is anyone successfully using this unit?  If so, please help! on Wed, 15 Jul 2020 00:48:08 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for the above comments.</p>
<p dir="auto">I am using the official M5Stack but bought from different suppliers from here in the UK.</p>
<p dir="auto">I have now tested the 3 units successfully by accessing them directly via the I2C bus address and registers rather than the UIFlow Unit ExtIO libraries.  I can read and write to the IO using this method so I suspect there is a bug in one of the UIFlow library routines.  I have raised this with M5Stack and I believe they are looking into it.</p>
<p dir="auto">It would still be great to know how others are using and accessing the ExtIO Unit especially using it via the Pa.Hub.  Thank you again.</p>
]]></description><link>https://community.m5stack.com/post/9336</link><guid isPermaLink="true">https://community.m5stack.com/post/9336</guid><dc:creator><![CDATA[samjami]]></dc:creator><pubDate>Wed, 15 Jul 2020 00:48:08 GMT</pubDate></item><item><title><![CDATA[Reply to EXTEND IO Unit - is anyone successfully using this unit?  If so, please help! on Fri, 10 Jul 2020 10:05:51 GMT]]></title><description><![CDATA[<p dir="auto">UIFlow only support M5Stack brand <a href="http://EXT.IO" target="_blank" rel="noopener noreferrer nofollow ugc">EXT.IO</a> Unit.   for other brand ,if you want to use they in the UIFlow. you need check they has same pins and chip etc.</p>
]]></description><link>https://community.m5stack.com/post/9295</link><guid isPermaLink="true">https://community.m5stack.com/post/9295</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 10 Jul 2020 10:05:51 GMT</pubDate></item><item><title><![CDATA[Reply to EXTEND IO Unit - is anyone successfully using this unit?  If so, please help! on Thu, 09 Jul 2020 10:07:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crami25" aria-label="Profile: crami25">@<bdi>crami25</bdi></a> might be able to help you...<br />
<a href="https://forum.m5stack.com/topic/1820/ext-io-unit-and-uiflow-1-4-5-1" target="_blank" rel="noopener noreferrer nofollow ugc">https://forum.m5stack.com/topic/1820/ext-io-unit-and-uiflow-1-4-5-1</a></p>
]]></description><link>https://community.m5stack.com/post/9281</link><guid isPermaLink="true">https://community.m5stack.com/post/9281</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Thu, 09 Jul 2020 10:07:43 GMT</pubDate></item></channel></rss>
