<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Atom Switch &amp; Modbus]]></title><description><![CDATA[<p dir="auto">Has anybody got the RS485 port on the Atom Switch module to function? I'd like to use it as a Modbus Master and read data from a serially-connected slave, but none of the example code that I've found works when I connect the unit to my existing trunk. (I've got a modbus scanning tool that I use and can see my other devices on the bus, but not the Atom Switch module, with either wiring polarity termination).</p>
]]></description><link>https://community.m5stack.com/topic/2136/atom-switch-modbus</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 16:06:15 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2136.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Jul 2020 22:17:05 GMT</pubDate><ttl>60</ttl></channel></rss>
