<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[All IDE refuse to work with M5Stack now]]></title><description><![CDATA[<p dir="auto">Hi!;<br />
First of all I wanted to say thanks for 1.6.1 FW which looks like a great progress and overall feel is much better! Great job;<br />
However<br />
None of IDE excepting online UIFlow works with M5Stack core now.<br />
VS Code won't connect.<br />
MU gives multiple error and can't access M5 storage;<br />
THonny connects and browses storage but can't save/run anything<br />
UIFlow offline version is outdated.</p>
<p dir="auto">Are there any plans to upgrade offline UIFlow at least? Online one isn't much convinient. MU/THonny looks just okay too.<br />
I can't build device fw with color blocks lol, want to type some;<br />
Thanks</p>
]]></description><link>https://community.m5stack.com/topic/2167/all-ide-refuse-to-work-with-m5stack-now</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 05:07:14 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2167.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Jul 2020 17:06:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to All IDE refuse to work with M5Stack now on Sat, 01 Aug 2020 18:22:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a><br />
Hi, yes, with some updating and couple restarts VS Code now working with 1.6.1 UIFlow firmware</p>
<p dir="auto">Thank you</p>
]]></description><link>https://community.m5stack.com/post/9561</link><guid isPermaLink="true">https://community.m5stack.com/post/9561</guid><dc:creator><![CDATA[Thrasher]]></dc:creator><pubDate>Sat, 01 Aug 2020 18:22:16 GMT</pubDate></item><item><title><![CDATA[Reply to All IDE refuse to work with M5Stack now on Fri, 31 Jul 2020 10:54:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thrasher" aria-label="Profile: thrasher">@<bdi>thrasher</bdi></a> update your vscode and plugin and UIFlow desktop IDE to last version. then try again.</p>
]]></description><link>https://community.m5stack.com/post/9536</link><guid isPermaLink="true">https://community.m5stack.com/post/9536</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 31 Jul 2020 10:54:05 GMT</pubDate></item><item><title><![CDATA[Reply to All IDE refuse to work with M5Stack now on Thu, 30 Jul 2020 21:57:32 GMT]]></title><description><![CDATA[<p dir="auto">Yeah thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus" aria-label="Profile: lukasmaximus">@<bdi>lukasmaximus</bdi></a>  and <a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a><br />
Ofcourse its on USB mode, I spent day trying different tricks with MU and THonny but I was using m5stack basic gray module, not stickC/Atom (I have them both so will try hopefully this weekend)<br />
VS Code won't work still, it sends M5Stack into reboot and than can't access its inner memory, but it could be a driver issue, will keep trying</p>
<p dir="auto">What's about offline uiflow ide?</p>
]]></description><link>https://community.m5stack.com/post/9518</link><guid isPermaLink="true">https://community.m5stack.com/post/9518</guid><dc:creator><![CDATA[Thrasher]]></dc:creator><pubDate>Thu, 30 Jul 2020 21:57:32 GMT</pubDate></item><item><title><![CDATA[Reply to All IDE refuse to work with M5Stack now on Thu, 30 Jul 2020 09:30:57 GMT]]></title><description><![CDATA[<p dir="auto">Make sure you have the stickC in USB mode, it's a little tricky, you need to hit the button on the right side really quickly on bootup. If you want to use in MU you need to change a config file, I mention it in this video <a href="https://youtu.be/15JrXn_9OWQ?t=80" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/15JrXn_9OWQ?t=80</a></p>
]]></description><link>https://community.m5stack.com/post/9505</link><guid isPermaLink="true">https://community.m5stack.com/post/9505</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Thu, 30 Jul 2020 09:30:57 GMT</pubDate></item><item><title><![CDATA[Reply to All IDE refuse to work with M5Stack now on Thu, 30 Jul 2020 02:03:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thrasher" aria-label="Profile: thrasher">@<bdi>thrasher</bdi></a> did you setup the device to USB mode?</p>
<p dir="auto">we has test it. it working normal with vscode.  maybe you could try to erase flash then upload the firmware  again.</p>
]]></description><link>https://community.m5stack.com/post/9496</link><guid isPermaLink="true">https://community.m5stack.com/post/9496</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 30 Jul 2020 02:03:25 GMT</pubDate></item><item><title><![CDATA[Reply to All IDE refuse to work with M5Stack now on Wed, 29 Jul 2020 11:12:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a>  M5Stack core gray with 1.6.1 UIFlow firmware</p>
]]></description><link>https://community.m5stack.com/post/9491</link><guid isPermaLink="true">https://community.m5stack.com/post/9491</guid><dc:creator><![CDATA[Thrasher]]></dc:creator><pubDate>Wed, 29 Jul 2020 11:12:37 GMT</pubDate></item><item><title><![CDATA[Reply to All IDE refuse to work with M5Stack now on Wed, 29 Jul 2020 10:48:51 GMT]]></title><description><![CDATA[<p dir="auto">which device are you use?</p>
]]></description><link>https://community.m5stack.com/post/9490</link><guid isPermaLink="true">https://community.m5stack.com/post/9490</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 29 Jul 2020 10:48:51 GMT</pubDate></item><item><title><![CDATA[Reply to All IDE refuse to work with M5Stack now on Wed, 29 Jul 2020 08:26:40 GMT]]></title><description><![CDATA[<p dir="auto">I'm not sure but there's probably major changes with 1.6 and later. Thats why UIFlow desktop not upgrading aswell</p>
]]></description><link>https://community.m5stack.com/post/9485</link><guid isPermaLink="true">https://community.m5stack.com/post/9485</guid><dc:creator><![CDATA[Thrasher]]></dc:creator><pubDate>Wed, 29 Jul 2020 08:26:40 GMT</pubDate></item><item><title><![CDATA[Reply to All IDE refuse to work with M5Stack now on Wed, 29 Jul 2020 04:54:17 GMT]]></title><description><![CDATA[<p dir="auto">I'm finding this aswel.<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> any idea what happened?</p>
]]></description><link>https://community.m5stack.com/post/9480</link><guid isPermaLink="true">https://community.m5stack.com/post/9480</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 29 Jul 2020 04:54:17 GMT</pubDate></item><item><title><![CDATA[Reply to All IDE refuse to work with M5Stack now on Tue, 28 Jul 2020 22:56:06 GMT]]></title><description><![CDATA[<p dir="auto">I have found the same with USB connected devices they are very difficult to connect with.</p>
]]></description><link>https://community.m5stack.com/post/9479</link><guid isPermaLink="true">https://community.m5stack.com/post/9479</guid><dc:creator><![CDATA[kylebuttress]]></dc:creator><pubDate>Tue, 28 Jul 2020 22:56:06 GMT</pubDate></item></channel></rss>
