<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Servo type Digital&#x2F;Analogue]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I was looking at the documentation on the servo module, i did not find anywhere which type to use (digital/Analogue). Anyone have tried Digital servo 360 on this module ?. I bought 2 of them and tried to do a simple loop to turn 90 degree, the servo keeps rotating 360 continuously, any help will be much appreciated.</p>
<p dir="auto">M5Stack Servo Driver Module<br />
Arduino Compatible Metal Gear Digital - 360</p>
]]></description><link>https://community.m5stack.com/topic/2168/servo-type-digital-analogue</link><generator>RSS for Node</generator><lastBuildDate>Sun, 03 May 2026 20:54:54 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2168.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Jul 2020 20:51:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Servo type Digital&#x2F;Analogue on Thu, 03 Sep 2020 00:54:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/guit" aria-label="Profile: guit">@<bdi>guit</bdi></a> said in <a href="/post/9915">Servo type Digital/Analogue</a>:</p>
<p dir="auto">I have done the same mistake. Is it possible to control the speed? and the rotation direction?</p>
<p dir="auto">Yes, with the 360 servo, this flow will rotate both directions at varying speeds. 1500 is the stop point. Values below 1000 or above 2000 didn't seem to affect the speed.</p>
<p dir="auto">Clockwise: 1000 (fast) to 1400 (slow), then 1500 (stopped)<br />
Counter-clockwise: 1500 (stopped), then 1600 (slow) to 2000 (fast)</p>
<p dir="auto"><img src="/assets/uploads/files/1599094379833-screen-shot-2020-09-02-at-8.48.03-pm-resized.png" alt="0_1599094367951_Screen Shot 2020-09-02 at 8.48.03 PM.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/9916</link><guid isPermaLink="true">https://community.m5stack.com/post/9916</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Thu, 03 Sep 2020 00:54:03 GMT</pubDate></item><item><title><![CDATA[Reply to Servo type Digital&#x2F;Analogue on Wed, 02 Sep 2020 21:12:47 GMT]]></title><description><![CDATA[<p dir="auto">I have done the same mistake. Is it possible to control the speed? and the rotation direction?</p>
]]></description><link>https://community.m5stack.com/post/9915</link><guid isPermaLink="true">https://community.m5stack.com/post/9915</guid><dc:creator><![CDATA[Guit]]></dc:creator><pubDate>Wed, 02 Sep 2020 21:12:47 GMT</pubDate></item><item><title><![CDATA[Reply to Servo type Digital&#x2F;Analogue on Sat, 01 Aug 2020 06:45:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/santoshym" aria-label="Profile: santoshym">@<bdi>santoshym</bdi></a> I have the 360 servos aswell but the control boards have been removed from the servos so speed control isn't possible.</p>
]]></description><link>https://community.m5stack.com/post/9552</link><guid isPermaLink="true">https://community.m5stack.com/post/9552</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 01 Aug 2020 06:45:57 GMT</pubDate></item><item><title><![CDATA[Reply to Servo type Digital&#x2F;Analogue on Sat, 01 Aug 2020 04:49:44 GMT]]></title><description><![CDATA[<p dir="auto">I have 2 servo 360,  did a simple loop, changing the value to 90 stops the servo any other value spins constantly. This also has a pot, i have not tried changing the value.</p>
]]></description><link>https://community.m5stack.com/post/9551</link><guid isPermaLink="true">https://community.m5stack.com/post/9551</guid><dc:creator><![CDATA[Santoshym]]></dc:creator><pubDate>Sat, 01 Aug 2020 04:49:44 GMT</pubDate></item><item><title><![CDATA[Reply to Servo type Digital&#x2F;Analogue on Thu, 30 Jul 2020 09:02:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/santoshym" aria-label="Profile: Santoshym">@<bdi>Santoshym</bdi></a> sounds like you bought a continuous rotation servo. Regular servos which have a limited range will have a small potentiometer inside which is connected to the drive shaft. You can have a look inside, it's possible to modify but a little tricky</p>
]]></description><link>https://community.m5stack.com/post/9504</link><guid isPermaLink="true">https://community.m5stack.com/post/9504</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Thu, 30 Jul 2020 09:02:23 GMT</pubDate></item><item><title><![CDATA[Reply to Servo type Digital&#x2F;Analogue on Thu, 30 Jul 2020 01:28:44 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, I brought a wrong servo then.</p>
]]></description><link>https://community.m5stack.com/post/9495</link><guid isPermaLink="true">https://community.m5stack.com/post/9495</guid><dc:creator><![CDATA[Santoshym]]></dc:creator><pubDate>Thu, 30 Jul 2020 01:28:44 GMT</pubDate></item><item><title><![CDATA[Reply to Servo type Digital&#x2F;Analogue on Wed, 29 Jul 2020 04:57:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/santoshym" aria-label="Profile: santoshym">@<bdi>santoshym</bdi></a> The 360's are just motors and have no position control, they are just on or off.<br />
for position control you need the servo 180.</p>
]]></description><link>https://community.m5stack.com/post/9481</link><guid isPermaLink="true">https://community.m5stack.com/post/9481</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 29 Jul 2020 04:57:24 GMT</pubDate></item></channel></rss>
