<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to control m5stickc pins via uiflow?]]></title><description><![CDATA[<p dir="auto">I want to connect a relay module to pin G26 with Easy I/O but nothing happen... pin G26 still have 3V even I already set it "digital write pin G26 value 0"<img src="https://docs.m5stack.com/image/Advanced%20module/EasyIO.webp" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/2173/how-to-control-m5stickc-pins-via-uiflow</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 16:23:45 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2173.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Jul 2020 10:38:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to control m5stickc pins via uiflow? on Fri, 31 Jul 2020 18:34:36 GMT]]></title><description><![CDATA[<p dir="auto">Thats mean the pin where you connect relay is set to low state. So if you want to turn off your relay you must set pin to high mode or use for example transistor inverter (or use not logic gate) to invert your signal if you want activate it in high state signal.</p>
<p dir="auto"><img src="/assets/uploads/files/1596220463390-bjt-amplifier-ce-positive-output.jpg" alt="0_1596220461992_bjt-amplifier-ce-positive-output.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/9546</link><guid isPermaLink="true">https://community.m5stack.com/post/9546</guid><dc:creator><![CDATA[robalstona]]></dc:creator><pubDate>Fri, 31 Jul 2020 18:34:36 GMT</pubDate></item><item><title><![CDATA[Reply to How to control m5stickc pins via uiflow? on Fri, 31 Jul 2020 12:51:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robalstona" aria-label="Profile: robalstona">@<bdi>robalstona</bdi></a> Now I figure out that the relay is an active-low device, but it always trigger when i connect it to m5stickc. Is my relay malfunctioned?</p>
]]></description><link>https://community.m5stack.com/post/9542</link><guid isPermaLink="true">https://community.m5stack.com/post/9542</guid><dc:creator><![CDATA[D3f4u1t]]></dc:creator><pubDate>Fri, 31 Jul 2020 12:51:01 GMT</pubDate></item><item><title><![CDATA[Reply to How to control m5stickc pins via uiflow? on Fri, 31 Jul 2020 12:40:03 GMT]]></title><description><![CDATA[<p dir="auto">ewentually power relay module from lover voltage ~3.5-4V. Then should be trigered with 3.3V in in. But in this case the pover voltage could be too low to correct work of relay( may not work in all cases when you trigger it. I had similar problem when i drive this relay from raspberry pi (also 3.3 logic level)</p>
]]></description><link>https://community.m5stack.com/post/9541</link><guid isPermaLink="true">https://community.m5stack.com/post/9541</guid><dc:creator><![CDATA[robalstona]]></dc:creator><pubDate>Fri, 31 Jul 2020 12:40:03 GMT</pubDate></item><item><title><![CDATA[Reply to How to control m5stickc pins via uiflow? on Fri, 31 Jul 2020 12:33:24 GMT]]></title><description><![CDATA[<p dir="auto">try another pullup eg PULL_UP<br />
Probably i mistake with these pins G36 can be use only as input and G26 should work( i wrote this earlier from memory). If you connect this relay module to stick you must connect gnd from module with gnd in stick. If you power relay module from 5V then input signal probably must be a higher than 3.5V (high signal from stick has lower level than needed to trigger relay) on in case when its activate as high signal. Try module alone to connect gnd to in and vcc from module to in, when you will known which signal you must take to trigger LOW or HIGH.<br />
At the last you could use G0, but you could problems when you power up or restart stick (if G0 has been in low when stick run in flash mode)</p>
]]></description><link>https://community.m5stack.com/post/9540</link><guid isPermaLink="true">https://community.m5stack.com/post/9540</guid><dc:creator><![CDATA[robalstona]]></dc:creator><pubDate>Fri, 31 Jul 2020 12:33:24 GMT</pubDate></item><item><title><![CDATA[Reply to How to control m5stickc pins via uiflow? on Fri, 31 Jul 2020 11:30:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/iamliubo" aria-label="Profile: iamliubo">@<bdi>iamliubo</bdi></a> Yes, I measuring it with my multimeter</p>
]]></description><link>https://community.m5stack.com/post/9539</link><guid isPermaLink="true">https://community.m5stack.com/post/9539</guid><dc:creator><![CDATA[D3f4u1t]]></dc:creator><pubDate>Fri, 31 Jul 2020 11:30:18 GMT</pubDate></item><item><title><![CDATA[Reply to How to control m5stickc pins via uiflow? on Fri, 31 Jul 2020 11:32:11 GMT]]></title><description><![CDATA[<p dir="auto">Can anyone provide me an example codes?<br />
I want my m5stickc to control this relay via hat pins by UIFlow.<br />
<img src="https://th.cytron.io/image/cache/catalog/products/BB-RELAY-5V-01/BB-RELAY-5V-01-800x800.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/9538</link><guid isPermaLink="true">https://community.m5stack.com/post/9538</guid><dc:creator><![CDATA[D3f4u1t]]></dc:creator><pubDate>Fri, 31 Jul 2020 11:32:11 GMT</pubDate></item><item><title><![CDATA[Reply to How to control m5stickc pins via uiflow? on Fri, 31 Jul 2020 11:25:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robalstona" aria-label="Profile: robalstona">@<bdi>robalstona</bdi></a> The error has occured "type object 'Pin' has no attribute 'PULL_FLOAT"</p>
]]></description><link>https://community.m5stack.com/post/9537</link><guid isPermaLink="true">https://community.m5stack.com/post/9537</guid><dc:creator><![CDATA[D3f4u1t]]></dc:creator><pubDate>Fri, 31 Jul 2020 11:25:40 GMT</pubDate></item><item><title><![CDATA[Reply to How to control m5stickc pins via uiflow? on Fri, 31 Jul 2020 01:25:30 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/d3f4u1t" aria-label="Profile: d3f4u1t">@<bdi>d3f4u1t</bdi></a> ,</p>
<p dir="auto">I just test it and it work well.</p>
<p dir="auto">pin G26 still have 3V even I already set it "digital write pin G26 value 0"</p>
<p dir="auto">Are you measuring the result with a multimeter?</p>
]]></description><link>https://community.m5stack.com/post/9523</link><guid isPermaLink="true">https://community.m5stack.com/post/9523</guid><dc:creator><![CDATA[IAMLIUBO]]></dc:creator><pubDate>Fri, 31 Jul 2020 01:25:30 GMT</pubDate></item><item><title><![CDATA[Reply to How to control m5stickc pins via uiflow? on Fri, 31 Jul 2020 01:21:17 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/robalstona" aria-label="Profile: robalstona">@<bdi>robalstona</bdi></a> ,<br />
In fact, G36 can only be used as input, I think you should remember it wrong.</p>
]]></description><link>https://community.m5stack.com/post/9522</link><guid isPermaLink="true">https://community.m5stack.com/post/9522</guid><dc:creator><![CDATA[IAMLIUBO]]></dc:creator><pubDate>Fri, 31 Jul 2020 01:21:17 GMT</pubDate></item><item><title><![CDATA[Reply to How to control m5stickc pins via uiflow? on Thu, 30 Jul 2020 13:10:41 GMT]]></title><description><![CDATA[<p dir="auto">G26 could be use only as input. Change pin to another eg. G36 and should work. Alternativelly<br />
Try use Advanced -&gt;PIN blocks<br />
use <strong>init</strong> block, change mode to OUT and pull to PULL_FLOAT to set your pin in output mode  then set your pin with <strong>set</strong> pin block.</p>
]]></description><link>https://community.m5stack.com/post/9511</link><guid isPermaLink="true">https://community.m5stack.com/post/9511</guid><dc:creator><![CDATA[robalstona]]></dc:creator><pubDate>Thu, 30 Jul 2020 13:10:41 GMT</pubDate></item></channel></rss>
