<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[new m5stack: Failed to write to target RAM (result was 01070000)]]></title><description><![CDATA[<p dir="auto">hello!<br />
just got a new (first) m5stack, and am stuck at:</p>
<li>Serial port /dev/cu.SLAB_USBtoUART<br />
Connecting........__<br />
Chip is ESP32D0WDQ6 (revision 1)<br />
MAC: 24:6f:28:8f:d1:54<br />
Uploading stub...<br />
A fatal error occurred: Failed to write to target RAM (result was 01070000)</li>
<p dir="auto">this happens with M5burner as well as Arduino configured with the ESP32 board specs. MacOS10.14.6 with the USB driver. tried all baud rates with the same result. (NB: had to un-quarantine M5burner with xattr, even though copied in /Applications).</p>
<p dir="auto">any thoughts?</p>
]]></description><link>https://community.m5stack.com/topic/2175/new-m5stack-failed-to-write-to-target-ram-result-was-01070000</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 15:37:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2175.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Jul 2020 19:48:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Fri, 01 Jul 2022 16:58:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/drjakob" aria-label="Profile: drjakob">@<bdi>drjakob</bdi></a> Check which USB driver is in the new cores as the driver chip was changed due to the part shortage.</p>
]]></description><link>https://community.m5stack.com/post/17872</link><guid isPermaLink="true">https://community.m5stack.com/post/17872</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 01 Jul 2022 16:58:24 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Thu, 30 Jun 2022 21:37:13 GMT]]></title><description><![CDATA[<p dir="auto">I still have the same problem with 5 new M5Fire on Big Sur. Two older ones burned succesful.</p>
]]></description><link>https://community.m5stack.com/post/17852</link><guid isPermaLink="true">https://community.m5stack.com/post/17852</guid><dc:creator><![CDATA[drjakob]]></dc:creator><pubDate>Thu, 30 Jun 2022 21:37:13 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Wed, 18 May 2022 17:40:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/parahooner" aria-label="Profile: parahooner">@<bdi>parahooner</bdi></a> Very many thanks for posting this, it completely resolved the problem.</p>
]]></description><link>https://community.m5stack.com/post/17522</link><guid isPermaLink="true">https://community.m5stack.com/post/17522</guid><dc:creator><![CDATA[Bludotz]]></dc:creator><pubDate>Wed, 18 May 2022 17:40:07 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Fri, 11 Feb 2022 21:28:41 GMT]]></title><description><![CDATA[<p dir="auto">I found a solution that works on Montery  :-)</p>
<p dir="auto">Make sure you follow the PDF instructions, this works M1 Mac M5 Epaper</p>
<p dir="auto"><a href="http://www.wch.cn/downloads/CH34XSER_MAC_ZIP.html" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.wch.cn/downloads/CH34XSER_MAC_ZIP.html</a></p>
]]></description><link>https://community.m5stack.com/post/16621</link><guid isPermaLink="true">https://community.m5stack.com/post/16621</guid><dc:creator><![CDATA[parahooner]]></dc:creator><pubDate>Fri, 11 Feb 2022 21:28:41 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Tue, 04 Jan 2022 07:35:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mackone" aria-label="Profile: mackone">@<bdi>mackone</bdi></a> try connecting the downloader's 3V3 to Stamp Pico's 5V</p>
]]></description><link>https://community.m5stack.com/post/16042</link><guid isPermaLink="true">https://community.m5stack.com/post/16042</guid><dc:creator><![CDATA[labixiaoxin8888]]></dc:creator><pubDate>Tue, 04 Jan 2022 07:35:06 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Wed, 08 Dec 2021 13:38:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/exie" aria-label="Profile: exie">@<bdi>exie</bdi></a> said in <a href="/post/15759">new m5stack: Failed to write to target RAM (result was 01070000)</a>:</p>
<p dir="auto">I have the same issue when I use the M5Stack ESP32 Downloader.<br />
However when I use a simple M5Stack Atom Matrix, its works fine.</p>
<p dir="auto">I am on OSX Big Sir.</p>
<p dir="auto">I feel like the issue is related to the CH9102 chip on the ESP32 Downloader where the Atom has the CP2104 I think.<br />
This theory is supported by this article here:<br />
<a href="https://blog.squix.org/2021/08/ch9102-driver-issues-failed-to-write-to-target-ram.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://blog.squix.org/2021/08/ch9102-driver-issues-failed-to-write-to-target-ram.html</a></p>
<p dir="auto">Confirmed, installing the driver from this thread here worked for me<br />
<a href="https://github.com/Xinyuan-LilyGO/LilyGo-T-Call-SIM800/issues/139" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Xinyuan-LilyGO/LilyGo-T-Call-SIM800/issues/139</a></p>
<p dir="auto">I guess you're right as I noticed on banggood/ aliexpress some products using this CH9102 chip are tagged as not Mac compatible.</p>
]]></description><link>https://community.m5stack.com/post/15761</link><guid isPermaLink="true">https://community.m5stack.com/post/15761</guid><dc:creator><![CDATA[erich]]></dc:creator><pubDate>Wed, 08 Dec 2021 13:38:07 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Wed, 08 Dec 2021 13:16:51 GMT]]></title><description><![CDATA[<p dir="auto">I have the same issue when I use the M5Stack ESP32 Downloader.<br />
]]></description><link>https://community.m5stack.com/post/15759</link><guid isPermaLink="true">https://community.m5stack.com/post/15759</guid><dc:creator><![CDATA[Exie]]></dc:creator><pubDate>Wed, 08 Dec 2021 13:16:51 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Tue, 07 Dec 2021 16:10:35 GMT]]></title><description><![CDATA[<p dir="auto">Has anyone managed to get the core 2 to work with an M1 mac?  I think that you do not need the driver for the m1?  With a m5stick C it works fine, but not with the core 2</p>
]]></description><link>https://community.m5stack.com/post/15744</link><guid isPermaLink="true">https://community.m5stack.com/post/15744</guid><dc:creator><![CDATA[slugs]]></dc:creator><pubDate>Tue, 07 Dec 2021 16:10:35 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Thu, 18 Nov 2021 10:15:02 GMT]]></title><description><![CDATA[<p dir="auto">I’m actually getting it with Catalina</p>
]]></description><link>https://community.m5stack.com/post/15511</link><guid isPermaLink="true">https://community.m5stack.com/post/15511</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 18 Nov 2021 10:15:02 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Thu, 18 Nov 2021 10:06:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/erich" aria-label="Profile: erich">@<bdi>erich</bdi></a> I'm on Mojave 10.14 and problem still exists :/</p>
]]></description><link>https://community.m5stack.com/post/15510</link><guid isPermaLink="true">https://community.m5stack.com/post/15510</guid><dc:creator><![CDATA[Mackone]]></dc:creator><pubDate>Thu, 18 Nov 2021 10:06:25 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Wed, 17 Nov 2021 15:49:31 GMT]]></title><description><![CDATA[<p dir="auto">This was a known issue with Big Sur (something related to the python and / or serial port implementation in Big Sur.<br />
I did contact M5Stack support but no solution has ever been found.<br />
I gave up and reverted back to Catalina and it worked fine again.<br />
Now I just installed the latest Monterey but haven't tested the Core2 yet.<br />
In the meantime I was also using a windows computer....</p>
]]></description><link>https://community.m5stack.com/post/15503</link><guid isPermaLink="true">https://community.m5stack.com/post/15503</guid><dc:creator><![CDATA[erich]]></dc:creator><pubDate>Wed, 17 Nov 2021 15:49:31 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Tue, 16 Nov 2021 17:30:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darul75" aria-label="Profile: darul75">@<bdi>darul75</bdi></a></p>
<p dir="auto">Same here - Have You found any solution?</p>
]]></description><link>https://community.m5stack.com/post/15496</link><guid isPermaLink="true">https://community.m5stack.com/post/15496</guid><dc:creator><![CDATA[Mackone]]></dc:creator><pubDate>Tue, 16 Nov 2021 17:30:58 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Tue, 16 Nov 2021 17:29:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a><br />
Same thing is happening to me:</p>
<p dir="auto">Start Burn<br />
"<br />
--chip esp32 --port /dev/tty.usbmodem53190095701 --baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x1000 /Applications/M5Burner.app/Contents/Resources/packages/fw/core/Core2_Tools-v1.0.0.bin</p>
<p dir="auto"><a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a> v2.5.0<br />
Serial port /dev/tty.usbmodem53190095701<br />
Connecting...</p>
<p dir="auto">Chip is ESP32D0WDQ6 (revision 1)<br />
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse<br />
MAC: 08:3a:f2:66:b7:70<br />
Uploading stub...</p>
<p dir="auto">A fatal error occurred: Failed to write to target RAM (result was 01070000)</p>
<p dir="auto">Burn Failed<br />
"</p>
<p dir="auto">Fighting for over 10 hours.. I'm dying here..</p>
]]></description><link>https://community.m5stack.com/post/15495</link><guid isPermaLink="true">https://community.m5stack.com/post/15495</guid><dc:creator><![CDATA[Mackone]]></dc:creator><pubDate>Tue, 16 Nov 2021 17:29:47 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Mon, 08 Nov 2021 19:05:01 GMT]]></title><description><![CDATA[<p dir="auto">I had weird problems like this with an M5Stamp-PICO until I put more capacitance across the bus (5V and 3.3V). I used a couple of tantalum capacitors I had on hand, not sure the value, probably 33uF. I was powering the device through the USB serial adapter and apparently it was power limited.<br />
I have had no problem whatsoever since then.</p>
]]></description><link>https://community.m5stack.com/post/15401</link><guid isPermaLink="true">https://community.m5stack.com/post/15401</guid><dc:creator><![CDATA[didier9]]></dc:creator><pubDate>Mon, 08 Nov 2021 19:05:01 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Mon, 08 Nov 2021 09:29:23 GMT]]></title><description><![CDATA[<p dir="auto">Great thanks, I will try again later, in the meantime I switched to a Windows machine to make it working.</p>
]]></description><link>https://community.m5stack.com/post/15393</link><guid isPermaLink="true">https://community.m5stack.com/post/15393</guid><dc:creator><![CDATA[darul75]]></dc:creator><pubDate>Mon, 08 Nov 2021 09:29:23 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Sun, 07 Nov 2021 08:50:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darul75" aria-label="Profile: darul75">@<bdi>darul75</bdi></a> said in <a href="/post/15382">new m5stack: Failed to write to target RAM (result was 01070000)</a>:</p>
<p dir="auto">I have installed latest driver <a href="https://www.silabs.com/documents/public/software/Mac_OSX_VCP_Driver.zip" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.silabs.com/documents/public/software/Mac_OSX_VCP_Driver.zip</a> and can see the corresponding extension in /Library/Extensions with</p>
<p dir="auto">drwxr-xr-x@  3 root  wheel    96 Oct 15 10:46 SiLabsUSBDriver.kext</p>
<p dir="auto">but then when running M5Burner it only show a tty device of type Bluetooth or usb modem</p>
<p dir="auto">ls /dev/tty.*</p>
<p dir="auto">/dev/tty.Bluetooth-Incoming-Port<br />
/dev/tty.usbmodem51850037101</p>
<p dir="auto">I am running macOS Catalina</p>
<p dir="auto">/dev/tty.usbmodem51850037101 is the correct device, I'm not sure what's going on in OSX but this is how it appears for me and the device that works for me.</p>
]]></description><link>https://community.m5stack.com/post/15386</link><guid isPermaLink="true">https://community.m5stack.com/post/15386</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 07 Nov 2021 08:50:29 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Sat, 06 Nov 2021 21:37:31 GMT]]></title><description><![CDATA[<p dir="auto">I have installed latest driver <a href="https://www.silabs.com/documents/public/software/Mac_OSX_VCP_Driver.zip" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.silabs.com/documents/public/software/Mac_OSX_VCP_Driver.zip</a> and can see the corresponding extension in /Library/Extensions with</p>
]]></description><link>https://community.m5stack.com/post/15382</link><guid isPermaLink="true">https://community.m5stack.com/post/15382</guid><dc:creator><![CDATA[darul75]]></dc:creator><pubDate>Sat, 06 Nov 2021 21:37:31 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Sat, 06 Nov 2021 21:17:00 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/zontex" aria-label="Profile: Zontex">@<bdi>Zontex</bdi></a> could you advise me also as I got a similar problem</p>
<p dir="auto">Start Burn</p>
<p dir="auto">--chip esp32 --port /dev/tty.usbmodem51850037101 --baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x7ff000 /Applications/M5Burner.app/Contents/Resources/packages/fw/other/wifi.bin 0x1000 /Applications/M5Burner.app/Contents/Resources/packages/fw/core/UIFlow_Core2-v1.8.5-core2.bin</p>
Serial port /dev/tty.usbmodem51850037101<br />
Connecting...<br />
.</p>
MAC: 08......HIDINGIT<br />
<p dir="auto">Burn Failed</p>
<p dir="auto">I guess it is the driver not loading well as I can only see this tty of type modem but I have found no easy way to make it working, I am using the Apple Multi Adaptor (HDMI/USB) on USB C.</p>
]]></description><link>https://community.m5stack.com/post/15381</link><guid isPermaLink="true">https://community.m5stack.com/post/15381</guid><dc:creator><![CDATA[darul75]]></dc:creator><pubDate>Sat, 06 Nov 2021 21:17:00 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Sat, 28 Nov 2020 21:49:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zontex" aria-label="Profile: zontex">@<bdi>zontex</bdi></a> Thanks a lot! Email sent with the full explanation of the issue</p>
]]></description><link>https://community.m5stack.com/post/10919</link><guid isPermaLink="true">https://community.m5stack.com/post/10919</guid><dc:creator><![CDATA[erich]]></dc:creator><pubDate>Sat, 28 Nov 2020 21:49:54 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Fri, 27 Nov 2020 08:44:42 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/erich" aria-label="Profile: erich">@<bdi>erich</bdi></a> , could you please send me an email so I could assist you regarding this issue: <a href="mailto:roni@m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">roni@m5stack.com</a> so I could assist you better?</p>
]]></description><link>https://community.m5stack.com/post/10895</link><guid isPermaLink="true">https://community.m5stack.com/post/10895</guid><dc:creator><![CDATA[Zontex]]></dc:creator><pubDate>Fri, 27 Nov 2020 08:44:42 GMT</pubDate></item><item><title><![CDATA[Reply to new m5stack: Failed to write to target RAM (result was 01070000) on Thu, 26 Nov 2020 20:42:11 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I'm also new with M5Stack products and have got the very same issue with a brand new Core 2.<br />
I am using VSCode + PlatformIO<br />
I am currently trying to test some basic code but end up with the same error when uploading my code.<br />
Have you solve the issue? Do you know what was the cause?<br />
Thanks<br />
Eric</p>
]]></description><link>https://community.m5stack.com/post/10888</link><guid isPermaLink="true">https://community.m5stack.com/post/10888</guid><dc:creator><![CDATA[erich]]></dc:creator><pubDate>Thu, 26 Nov 2020 20:42:11 GMT</pubDate></item></channel></rss>
