<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Connecting sensors to M5Stack and CAN Bus]]></title><description><![CDATA[<p dir="auto">Hello!<br />
Im new into this forum and microcontrollers / IoT world, but somehow I decided to focus my university thesis in that. For backgrund purposes, its a smart rollator that measures some data from patients in a rehab center that use it to measure their rehab progress and other parameters....I decided to use a M5Stack to capture data from:</p>
<p dir="auto">2 Weight amplifiers HX711 to measure force in the handlers.<br />
Encoder as5600 1828raf c, one in each wheel.<br />
2 standar servos, one in each brake, so the rollator can stop automatically in case of an user fall or potential danger.</p>
<p dir="auto">But as I have never worked with electronics, I dont know how to conect them to M5 Stack correctly. The connection can be done straight away or do I need some other elements in between? Theres is around 50cm-1m of distance between the position of the M5Stack and the other sensors/actuators. The original rollator (it doesn´t have a IoT app on it, just captures data) uses and arduino nano for each sensor so the data can be transmitted via CAN BUS to a raspberry Pi. Is this neccesary for M5Stack?</p>
<p dir="auto">Any kind of insight would be really helpful!<br />
Thank you!</p>
]]></description><link>https://community.m5stack.com/topic/2178/connecting-sensors-to-m5stack-and-can-bus</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:21:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2178.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 31 Jul 2020 13:40:33 GMT</pubDate><ttl>60</ttl></channel></rss>
