<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[OSX Easyloader]]></title><description><![CDATA[<p dir="auto">Re: [Custom EasyLoader](/topic/1771/OSX easyloader)</p>
<p dir="auto">Hi --<br />
It is not made clear on the M5STack website that the Atom is not programmable with OSX or Linux, but only with Wondows!  I own several useless Atoms.</p>
<p dir="auto">When will a method of programming these little wonders be made available?  Or open source it, and let the web do its magic.</p>
<p dir="auto">David</p>
]]></description><link>https://community.m5stack.com/topic/2182/osx-easyloader</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 20:14:02 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2182.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 02 Aug 2020 22:20:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to OSX Easyloader on Tue, 13 Oct 2020 17:25:33 GMT]]></title><description><![CDATA[<p dir="auto">I finally loaded Windows 10 into a VirtualBox VM, and that works for me.</p>
]]></description><link>https://community.m5stack.com/post/10265</link><guid isPermaLink="true">https://community.m5stack.com/post/10265</guid><dc:creator><![CDATA[dpharris]]></dc:creator><pubDate>Tue, 13 Oct 2020 17:25:33 GMT</pubDate></item><item><title><![CDATA[Reply to OSX Easyloader on Sat, 08 Aug 2020 18:37:49 GMT]]></title><description><![CDATA[<p dir="auto">Hi there</p>
<p dir="auto">some additional information: same Mac, same OS X Yosemite, same USB port, same USB cable and same M5AtomLite / Matrix, but using a virtual machine running Ubuntu 18.04 and flashing works just fine. I guess this suggest that there is some subtle difference in the FTDI driver of OS X and Ubuntu.</p>
<p dir="auto">Felix</p>
]]></description><link>https://community.m5stack.com/post/9605</link><guid isPermaLink="true">https://community.m5stack.com/post/9605</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 08 Aug 2020 18:37:49 GMT</pubDate></item><item><title><![CDATA[Reply to OSX Easyloader on Fri, 07 Aug 2020 15:07:31 GMT]]></title><description><![CDATA[<p dir="auto">Hi there</p>
<p dir="auto">Although I don't have a solution I wanted to share my results regarding flashing M5StickC, M5AtomLite and M5AtomMatrix . I am using VSCode/PlatformIO on two Macs with different OS:</p>
<li>
<p dir="auto">OS X Yosemite (10.10.5):<br />
M5StickC (success), M5AtomLite (fail), M5AtomMatrix (fail)</p>
</li>
<li>
<p dir="auto">macOS High Sierra (10.13.6):<br />
M5StickC (success), M5AtomLite (success), M5AtomMatrix (success)</p>
</li>
<p dir="auto">Checking System Information / USB I can see that M5StackC reports version 4.00 and the two M5Atoms show version 5.00.</p>
<p dir="auto">Anyways, from System Information / USB it looks like the custom USB chips in M5StickC and M5Atoms report as FTDI but I guess they aren't perfect copies and therefore different results are seen with different setups.</p>
]]></description><link>https://community.m5stack.com/post/9604</link><guid isPermaLink="true">https://community.m5stack.com/post/9604</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 07 Aug 2020 15:07:31 GMT</pubDate></item><item><title><![CDATA[Reply to OSX Easyloader on Fri, 07 Aug 2020 04:47:34 GMT]]></title><description><![CDATA[<p dir="auto">10.10.5?<br />
I'm running 10.14.2 (mojave) and can program using UIFlow and arduino.<br />
It could be that you OSX is too old to support it.<br />
Have you installed python3 ?<br />
what is the error message that the updater returns?</p>
]]></description><link>https://community.m5stack.com/post/9602</link><guid isPermaLink="true">https://community.m5stack.com/post/9602</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 07 Aug 2020 04:47:34 GMT</pubDate></item><item><title><![CDATA[Reply to OSX Easyloader on Thu, 06 Aug 2020 05:35:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a><br />
Thanks for that.  I have loaded all the libraries.  I have tried choosing M5StickC or ESP32-Pico for the AtomMatrix.  Neither the Atom, nor the M5StickCs will load.  I can load after powering up with G0 grounded.</p>
<p dir="auto">I have OSX 10.10.5.  I have tried the Updater_FW20200422 py program, but it fails.</p>
<p dir="auto">Thanks for any advice!</p>
]]></description><link>https://community.m5stack.com/post/9599</link><guid isPermaLink="true">https://community.m5stack.com/post/9599</guid><dc:creator><![CDATA[dpharris]]></dc:creator><pubDate>Thu, 06 Aug 2020 05:35:03 GMT</pubDate></item><item><title><![CDATA[Reply to OSX Easyloader on Thu, 06 Aug 2020 01:21:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dpharris" aria-label="Profile: dpharris">@<bdi>dpharris</bdi></a></p>
<p dir="auto">in this page you could choice the program platform.  and click the category card view the Quick Start.</p>
<p dir="auto"><a href="https://docs.m5stack.com/#/en/quick_start/atom/atom_quick_start" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/quick_start/atom/atom_quick_start</a></p>
]]></description><link>https://community.m5stack.com/post/9598</link><guid isPermaLink="true">https://community.m5stack.com/post/9598</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 06 Aug 2020 01:21:03 GMT</pubDate></item><item><title><![CDATA[Reply to OSX Easyloader on Wed, 05 Aug 2020 18:11:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a><br />
You can program them on OSX?</p>
<p dir="auto">If so, how do you do it?</p>
<p dir="auto">Thx David</p>
]]></description><link>https://community.m5stack.com/post/9597</link><guid isPermaLink="true">https://community.m5stack.com/post/9597</guid><dc:creator><![CDATA[dpharris]]></dc:creator><pubDate>Wed, 05 Aug 2020 18:11:53 GMT</pubDate></item><item><title><![CDATA[Reply to OSX Easyloader on Mon, 03 Aug 2020 04:36:54 GMT]]></title><description><![CDATA[<p dir="auto">You have installed the drivers properly have you because I have several Atoms and I can program them fine in Arduino and UIFlow</p>
]]></description><link>https://community.m5stack.com/post/9572</link><guid isPermaLink="true">https://community.m5stack.com/post/9572</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 03 Aug 2020 04:36:54 GMT</pubDate></item><item><title><![CDATA[Reply to OSX Easyloader on Mon, 03 Aug 2020 00:36:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dpharris" aria-label="Profile: dpharris">@<bdi>dpharris</bdi></a></p>
<p dir="auto">Edit: I haven’t seen an update on easyloader yet for OSX. In the meantime, use Arduino or uiFlow to program the Atom and m5burner to flash the firmware.</p>
]]></description><link>https://community.m5stack.com/post/9570</link><guid isPermaLink="true">https://community.m5stack.com/post/9570</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Mon, 03 Aug 2020 00:36:07 GMT</pubDate></item></channel></rss>
