<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ATOM Lite]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I need some help with ESP-IDF in a Atom Lite. I have two version of Atom Lite and one of Stick C.</p>
<p dir="auto">One version of Atom Lite has a label with the text "Adding Model-ATOM-2" with FCC details, the other version has a label with text "NOTE".</p>
<p dir="auto">See Photo: <a href="https://pasteboard.co/JlJHMAW.jpg" target="_blank" rel="noopener noreferrer nofollow ugc">https://pasteboard.co/JlJHMAW.jpg</a></p>
<p dir="auto">My program, designed with ESP-IDF, works perfect in Atom Lite with label "Adding Model-ATOM-2" and "ESP32 DevKit-C" but when I use the Atom Lite with label "NOTE" or Stick C, the wifi disconnects when registering with AP. Sometimes I can get a stable connection, but after many many tries and time.</p>
<p dir="auto">.<br />
<strong>==== DETAILS ====</strong><br />
ESP-IDF -  <strong>version</strong>: release/v4.0 - <strong>commit</strong>: 26d7fb774488adaa95253f278b5e62623cefab90<br />
Xtensa - <strong>version</strong>: esp-2020r2-8.2.0</p>
<p dir="auto"><strong>==== LOG ====</strong><br />
I (19078) wifi:state: run -&gt; init (2a0)<br />
I (19078) wifi:new:&lt;13,0&gt;, old:&lt;13,2&gt;, ap:&lt;255,255&gt;, sta:&lt;13,2&gt;, prof:1<br />
I (19078) wifi:new:&lt;13,0&gt;, old:&lt;13,0&gt;, ap:&lt;255,255&gt;, sta:&lt;13,2&gt;, prof:1<br />
D (19078) system_event: SYSTEM_EVENT_STA_DISCONNECTED, ssid:WIFI, ssid_len:4, bssid:70:2e:01:e1:a9:16, reason:15 (4-way keying handshake timeout)<br />
D (19098) event: running post WIFI_EVENT:5 with handler 0x400dd3e0 on loop 0x3ffbed64<br />
0x400dd3e0: handle_sta_disconnected at /esp-idf/components/tcpip_adapter/event_handlers.c:195</p>
<p dir="auto">D (19108) tcpip_adapter: if0 start ip lost tmr: enter<br />
D (19108) tcpip_adapter: if0 start ip lost tmr: no need start because netif=0x3ffc6ca4 interval=120 ip=0<br />
D (19118) event: running post WIFI_EVENT:5 with handler 0x400d48cc on loop 0x3ffbed64<br />
0x400d48cc: event_handler at /getting_started/station/build/../main/station_example_main.c:46</p>
<p dir="auto">I (19128) wifi station: retry to connect to the AP<br />
I (19128) wifi station: connect to the AP fail<br />
D (21178) system_event: SYSTEM_EVENT_STA_DISCONNECTED, ssid:WIFI, ssid_len:7, bssid:00:00:00:00:00:00, reason:205 (other reason)<br />
D (21178) event: running post WIFI_EVENT:5 with handler 0x400dd3e0 on loop 0x3ffbed64<br />
<p dir="auto">D (21188) tcpip_adapter: if0 start ip lost tmr: enter<br />
D (21188) tcpip_adapter: if0 start ip lost tmr: no need start because netif=0x3ffc6ca4 interval=120 ip=0<br />
D (21198) event: running post WIFI_EVENT:5 with handler 0x400d48cc on loop 0x3ffbed64<br />
<p dir="auto">I (21208) wifi station: retry to connect to the AP<br />
I (21218) wifi station: connect to the AP fail<br />
I (21568) wifi:new:&lt;13,2&gt;, old:&lt;13,0&gt;, ap:&lt;255,255&gt;, sta:&lt;13,2&gt;, prof:1<br />
I (21568) wifi:state: init -&gt; auth (b0)<br />
I (21598) wifi:state: auth -&gt; assoc (0)<br />
I (22598) wifi:state: assoc -&gt; init (400)<br />
I (22598) wifi:new:&lt;13,0&gt;, old:&lt;13,2&gt;, ap:&lt;255,255&gt;, sta:&lt;13,2&gt;, prof:1<br />
D (22598) system_event: SYSTEM_EVENT_STA_DISCONNECTED, ssid:WIFI, ssid_len:4, bssid:70:2e:01:e1:a9:16, reason:4 (assoc expire)<br />
D (22608) event: running post WIFI_EVENT:5 with handler 0x400dd3e0 on loop 0x3ffbed64<br />
<p dir="auto">D (22618) tcpip_adapter: if0 start ip lost tmr: enter<br />
D (22618) tcpip_adapter: if0 start ip lost tmr: no need start because netif=0x3ffc6ca4 interval=120 ip=0<br />
D (22628) event: running post WIFI_EVENT:5 with handler 0x400d48cc on loop 0x3ffbed64<br />
<p dir="auto">I (22638) wifi station: retry to connect to the AP<br />
I (22638) wifi station: connect to the AP fail<br />
D (24688) system_event: SYSTEM_EVENT_STA_DISCONNECTED, ssid:WIFi, ssid_len:4, bssid:00:00:00:00:00:00, reason:205 (other reason)<br />
D (24688) event: running post WIFI_EVENT:5 with handler 0x400dd3e0 on loop 0x3ffbed64<br />
<p dir="auto">D (24698) tcpip_adapter: if0 start ip lost tmr: enter<br />
D (24698) tcpip_adapter: if0 start ip lost tmr: no need start because netif=0x3ffc6ca4 interval=120 ip=0<br />
D (24708) event: running post WIFI_EVENT:5 with handler 0x400d48cc on loop 0x3ffbed64<br />
0x400d48cc: event_handler at /getting_started/station/build/../main/station_example_main.c:46<br />
...</p>
<p dir="auto">Do you have any ideas to try to solve this issue?</p>
<p dir="auto">Thanks &amp; Regards,<br />
Ricardo.</p>
]]></description><link>https://community.m5stack.com/topic/2193/atom-lite</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 17:19:21 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2193.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 10 Aug 2020 15:31:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ATOM Lite on Mon, 10 Aug 2020 15:53:37 GMT]]></title><description><![CDATA[<p dir="auto">To avoid possible conflicts with my app, I tested with Wifi Examples from ESP-IDF repo:<br />
<a href="https://github.com/espressif/esp-idf/blob/master/examples/wifi/getting_started/station/main/station_example_main.c" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/espressif/esp-idf/blob/master/examples/wifi/getting_started/station/main/station_example_main.c</a></p>
<p dir="auto">Sorry for this missing point.</p>
]]></description><link>https://community.m5stack.com/post/9619</link><guid isPermaLink="true">https://community.m5stack.com/post/9619</guid><dc:creator><![CDATA[ricardo.pereira]]></dc:creator><pubDate>Mon, 10 Aug 2020 15:53:37 GMT</pubDate></item></channel></rss>
