<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Gray Development Kit: IMU - SD Karte]]></title><description><![CDATA[<p dir="auto">Hallo!<br />
Hat jemand bereits Erfahrung im Umgang mit dem verbauten IMU des M5Stacks? Ich würde gerne die Daten des IMU aufnehmen und dann auf einer SD-Karte abspeichern, um später erneut diese aufzurufen zu können, um sie weiter zu bearbeiten.</p>
<p dir="auto">Über eine Antwort würde ich mich freuen!</p>
<p dir="auto">Gruß Jan</p>
]]></description><link>https://community.m5stack.com/topic/2194/m5stack-gray-development-kit-imu-sd-karte</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 11:16:51 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2194.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 12 Aug 2020 08:06:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack Gray Development Kit: IMU - SD Karte on Sun, 16 Aug 2020 15:08:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a><br />
Thank you for the answer!<br />
The example for the IMU works.<br />
The SD(esp32) example does not work on my M5Stack. So far I haven't found a way to save the data (using the command M5.IMU.getAccelData(&amp;accX,&amp;accY,&amp;accZ);) to an SD card. Do I have to convert my data into a string  to save it in a txt file or can I save the data directly as float variables?<br />
I also wanted to know if there is a command to display the acceleration data directly as a graph on the M5Stack display (and not just the value)?</p>
]]></description><link>https://community.m5stack.com/post/9685</link><guid isPermaLink="true">https://community.m5stack.com/post/9685</guid><dc:creator><![CDATA[jsh]]></dc:creator><pubDate>Sun, 16 Aug 2020 15:08:20 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Gray Development Kit: IMU - SD Karte on Wed, 12 Aug 2020 09:18:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jsh" aria-label="Profile: jsh">@<bdi>jsh</bdi></a> after install ESP32 board and M5Stack lib in Arduino IDE. you could find the ESP32 SD example and IMU example.  in the example list.</p>
]]></description><link>https://community.m5stack.com/post/9627</link><guid isPermaLink="true">https://community.m5stack.com/post/9627</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 12 Aug 2020 09:18:29 GMT</pubDate></item></channel></rss>
