<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to save data to SD-card]]></title><description><![CDATA[<p dir="auto">The UI flow is nice but you end nothing written to the file, it is only created - please provide an example. may be it needs some control characters<br />
thanks</p>
]]></description><link>https://community.m5stack.com/topic/2225/how-to-save-data-to-sd-card</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 16:08:38 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2225.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 20 Aug 2020 19:56:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to save data to SD-card on Fri, 21 Aug 2020 06:03:51 GMT]]></title><description><![CDATA[<p dir="auto">Would you mind adding some indication about control characters there, like "\r\n"<br />
Please recognize that you promised fast prototyping using the M5Stack but now it is clear that:</p>
<li>it is cumbersome, because the high level uiflow functions are not documented, and no working examples in micropython given to validate the high level functions</li>
<li>the combination of modules was not testet (ok a lot of variants)</li>
<li>the physical design has some flaws - the screen may brake when assembling, disassembling needs force - may be you may invent a receptacle with unlocking lever</li>
<p dir="auto">Do you have a  standard before selling modules for quality control, and a test plan?</p>
]]></description><link>https://community.m5stack.com/post/9778</link><guid isPermaLink="true">https://community.m5stack.com/post/9778</guid><dc:creator><![CDATA[Efried]]></dc:creator><pubDate>Fri, 21 Aug 2020 06:03:51 GMT</pubDate></item><item><title><![CDATA[Reply to How to save data to SD-card on Fri, 21 Aug 2020 02:25:50 GMT]]></title><description><![CDATA[<p dir="auto">you could refer the demo block.</p>
<p dir="auto"><img src="https://m5stack.oss-cn-shenzhen.aliyuncs.com/image/Forum_reply/sdcard_block_01.jpg" alt="替代文字" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/9777</link><guid isPermaLink="true">https://community.m5stack.com/post/9777</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 21 Aug 2020 02:25:50 GMT</pubDate></item></channel></rss>
