<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RS232 to M5 Basic&#x2F;Gray?]]></title><description><![CDATA[<p dir="auto">Hey Guys,<br />
I have a Basic and Gray Core and also have Commu modules with CAN and RS485.  What is the easiest way to get RS232 into the units?    Should I try an RS232 to RS485 converter, or should I go with another solution?  I see that there might be issues with the RS485 implementation in the commu module?</p>
<p dir="auto">In any case, trying to get RS232 serial data in to the Core to display it.</p>
<p dir="auto">If someone could point me in the right direction I would be grateful.</p>
<p dir="auto">Cheers!<br />
John</p>
]]></description><link>https://community.m5stack.com/topic/2226/rs232-to-m5-basic-gray</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 03:30:52 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2226.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 21 Aug 2020 01:56:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RS232 to M5 Basic&#x2F;Gray? on Fri, 21 Aug 2020 06:50:06 GMT]]></title><description><![CDATA[<p dir="auto">Hello John</p>
<p dir="auto">A couple of M5Stack modules (like GPS) already use a serial connection via GPIO16 and GPIO17. However GPIOs only provide logical voltage levels (0V / +3.3V).</p>
<p dir="auto">Assuming your source is a standard RS232 device the voltage levels can go down to -15V and up to +15V so you probably need a level converter like this one:</p>
<p dir="auto"><a href="https://www.amazon.com/Serial-Converter-Equipment-Upgrades-Doupont/dp/B01N42QW8X/ref=sr_1_6?crid=2OZ5U3Q7GY5OS&amp;dchild=1&amp;keywords=ttl+rs232+converter&amp;qid=1597992249&amp;sprefix=ttl+rs2%2Caps%2C276&amp;sr=8-6" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.amazon.com/Serial-Converter-Equipment-Upgrades-Doupont/dp/B01N42QW8X/ref=sr_1_6?crid=2OZ5U3Q7GY5OS&amp;dchild=1&amp;keywords=ttl+rs232+converter&amp;qid=1597992249&amp;sprefix=ttl+rs2%2Caps%2C276&amp;sr=8-6</a></p>
<p dir="auto">Cheers<br />
]]></description><link>https://community.m5stack.com/post/9780</link><guid isPermaLink="true">https://community.m5stack.com/post/9780</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 21 Aug 2020 06:50:06 GMT</pubDate></item></channel></rss>
