<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[m5stack Fire accident]]></title><description><![CDATA[<p dir="auto">I am a newby and wanted to upgrade the firmware of my m5stack fire. I downloaded the burner tool on osx, there i was connected to the usb port and did not see any buttons to upgrade the firmware. Then i accidently hit the erase button. And than , the bootloader was erased. Any idea to get it up and running with the Original stock software again? Or did i bricked it? In Windows i connected after this accident and showed the serial terminal showing<br />
flash read error 1000, and rst: 0x10, boot 0x17 ets_main .c 317</p>
]]></description><link>https://community.m5stack.com/topic/2244/m5stack-fire-accident</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 12:33:40 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2244.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 26 Aug 2020 18:45:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to m5stack Fire accident on Wed, 26 Aug 2020 19:27:17 GMT]]></title><description><![CDATA[<p dir="auto">Thanks a lot, I was almost there! I tried the UIflow firmware. The configuration button gave me an error. The burn asked me to connect to wifi. I asumed that it was the wifi of the m5, but thought that it would not work because the core was without OS. After your suggestion I unboxed the Core again (it was ready to send it back ;-) And now up and running again. Many thx ;-) Hopefully after the update the env II sensor wil work now. Because there the troubles started. Out of the box it did not work. Now i will retry.</p>
]]></description><link>https://community.m5stack.com/post/9852</link><guid isPermaLink="true">https://community.m5stack.com/post/9852</guid><dc:creator><![CDATA[rdegrootq]]></dc:creator><pubDate>Wed, 26 Aug 2020 19:27:17 GMT</pubDate></item><item><title><![CDATA[Reply to m5stack Fire accident on Wed, 26 Aug 2020 19:04:08 GMT]]></title><description><![CDATA[<p dir="auto">Click on the image of the core, and then click on the firmware for the fire to download to you computer.<br />
Once the firmware is downloaded you can then flash the firmware to the fire by clicking the burn button.</p>
<p dir="auto">Its very hard to brick the M5Stack cores.</p>
]]></description><link>https://community.m5stack.com/post/9850</link><guid isPermaLink="true">https://community.m5stack.com/post/9850</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 26 Aug 2020 19:04:08 GMT</pubDate></item></channel></rss>
