<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Neoflash HAT]]></title><description><![CDATA[<p dir="auto">Hi all,  I'm testing Neoflash HAT with M5StickC but with this code:</p>
<pre><code>/*
    Please install FastLED library first.
    In arduino library manage search FastLED
#include &lt;M5StickC.h&gt;
#include "FastLED.h"
FASTLED_USING_NAMESPACE
// FastLED "100-lines-of-code" demo reel, showing just a few
// of the kinds of animation patterns you can quickly and easily
// compose using FastLED.
// This example also shows one easy way to define multiple
// animations patterns and have them automatically rotate.
// -Mark Kriegsman, December 2014
#if defined(FASTLED_VERSION) &amp;&amp; (FASTLED_VERSION &lt; 3001000)
#warning "Requires FastLED 3.1 or later; check github for latest code."
#endif
#define DATA_PIN    26
//#define CLK_PIN   4
#define LED_TYPE    WS2811
#define COLOR_ORDER GRB
#define NUM_LEDS    126
CRGB leds[NUM_LEDS];
#define BRIGHTNESS          30
#define FRAMES_PER_SECOND  120
// -- The core to run FastLED.show()
#define FASTLED_SHOW_CORE 0
// -- Task handles for use in the notifications
static TaskHandle_t FastLEDshowTaskHandle = 0;
static TaskHandle_t userTaskHandle = 0;
/** show() for ESP32
 *  Call this function instead of FastLED.show(). It signals core 0 to issue a show,
 *  then waits for a notification that it is done.
void FastLEDshowESP32()
    if (userTaskHandle == 0) {
        // -- Store the handle of the current task, so that the show task can
        //    notify it when it's done
        userTaskHandle = xTaskGetCurrentTaskHandle();
        // -- Trigger the show task
        xTaskNotifyGive(FastLEDshowTaskHandle);
        // -- Wait to be notified that it's done
        const TickType_t xMaxBlockTime = pdMS_TO_TICKS( 200 );
        ulTaskNotifyTake(pdTRUE, xMaxBlockTime);
        userTaskHandle = 0;
/** show Task
 *  This function runs on core 0 and just waits for requests to call FastLED.show()
void FastLEDshowTask(void *pvParameters)
    // -- Run forever...
    for(;;) {
        // -- Wait for the trigger
        ulTaskNotifyTake(pdTRUE, portMAX_DELAY);
        // -- Do the show (synchronously)
        FastLED.show();
        // -- Notify the calling task
        xTaskNotifyGive(userTaskHandle);
  M5.begin();
  delay(3000); // 3 second delay for recovery
  Serial.begin(115200);
  M5.Lcd.setRotation(3);
  M5.Lcd.fillScreen(BLACK);
  M5.Lcd.setTextSize(2);
  M5.Lcd.setCursor(10, 0);
  M5.Lcd.setTextColor(TFT_LIGHTGREY);
  M5.Lcd.print("NeoFlash HAT\r\n");
  M5.Lcd.setCursor(60, 30);
  M5.Lcd.setTextColor(TFT_NAVY);
  M5.Lcd.print("RGB");
  M5.Lcd.setCursor(30, 50);
  M5.Lcd.print("EFFICTION");
  // tell FastLED about the LED strip configuration
  FastLED.addLeds&lt;LED_TYPE,DATA_PIN,COLOR_ORDER&gt;(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  //FastLED.addLeds&lt;LED_TYPE,DATA_PIN,CLK_PIN,COLOR_ORDER&gt;(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  // set master brightness control
  FastLED.setBrightness(BRIGHTNESS);
    int core = xPortGetCoreID();
    Serial.print("Main code running on core ");
    Serial.println(core);
    // -- Create the FastLED show task
    xTaskCreatePinnedToCore(FastLEDshowTask, "FastLEDshowTask", 2048, NULL, 2, &amp;FastLEDshowTaskHandle, FASTLED_SHOW_CORE);
// List of patterns to cycle through.  Each is defined as a separate function below.
typedef void (*SimplePatternList[])();
SimplePatternList gPatterns = { rainbow, rainbowWithGlitter, confetti, sinelon, juggle, bpm };
uint8_t gCurrentPatternNumber = 0; // Index number of which pattern is current
uint8_t gHue = 0; // rotating "base color" used by many of the patterns
void loop()
  // Call the current pattern function once, updating the 'leds' array
  gPatterns[gCurrentPatternNumber]();
  // send the 'leds' array out to the actual LED strip
  FastLEDshowESP32();
  // FastLED.show();
  // insert a delay to keep the framerate modest
  FastLED.delay(1000/FRAMES_PER_SECOND);
  // do some periodic updates
  EVERY_N_MILLISECONDS( 20 ) { gHue++; } // slowly cycle the "base color" through the rainbow
  EVERY_N_SECONDS( 10 ) { nextPattern(); } // change patterns periodically
#define ARRAY_SIZE(A) (sizeof(A) / sizeof((A)[0]))
void nextPattern()
  // add one to the current pattern number, and wrap around at the end
  gCurrentPatternNumber = (gCurrentPatternNumber + 1) % ARRAY_SIZE( gPatterns);
void rainbow()
  // FastLED's built-in rainbow generator
  fill_rainbow( leds, NUM_LEDS, gHue, 7);
void rainbowWithGlitter()
  // built-in FastLED rainbow, plus some random sparkly glitter
  rainbow();
  addGlitter(80);
void addGlitter( fract8 chanceOfGlitter)
  if( random8() &lt; chanceOfGlitter) {
    leds[ random16(NUM_LEDS) ] += CRGB::White;
void confetti()
  // random colored speckles that blink in and fade smoothly
  fadeToBlackBy( leds, NUM_LEDS, 10);
  int pos = random16(NUM_LEDS);
  leds[pos] += CHSV( gHue + random8(64), 200, 255);
void sinelon()
  // a colored dot sweeping back and forth, with fading trails
  fadeToBlackBy( leds, NUM_LEDS, 20);
  int pos = beatsin16( 13, 0, NUM_LEDS-1 );
  leds[pos] += CHSV( gHue, 255, 192);
void bpm()
  // colored stripes pulsing at a defined Beats-Per-Minute (BPM)
  uint8_t BeatsPerMinute = 62;
  CRGBPalette16 palette = PartyColors_p;
  uint8_t beat = beatsin8( BeatsPerMinute, 64, 255);
  for( int i = 0; i &lt; NUM_LEDS; i++) { //9948
    leds[i] = ColorFromPalette(palette, gHue+(i*2), beat-gHue+(i*10));
void juggle() {
  // eight colored dots, weaving in and out of sync with each other
  byte dothue = 0;
  for( int i = 0; i &lt; 8; i++) {
    leds[beatsin16( i+7, 0, NUM_LEDS-1 )] |= CHSV(dothue, 200, 255);
    dothue += 32;
<p dir="auto">but only fist line of neoflash Hat works....</p>
<p dir="auto">ideas??<br />
tnks a lot</p>
]]></description><link>https://community.m5stack.com/topic/2245/neoflash-hat</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 11:33:49 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2245.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 26 Aug 2020 20:13:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Neoflash HAT on Sun, 12 Sep 2021 12:27:09 GMT]]></title><description><![CDATA[<p dir="auto">A year ago?</p>
<p dir="auto">It looks to me like you have a duff RGB panel. Did you ever get it swapped?</p>
]]></description><link>https://community.m5stack.com/post/14867</link><guid isPermaLink="true">https://community.m5stack.com/post/14867</guid><dc:creator><![CDATA[SarahC]]></dc:creator><pubDate>Sun, 12 Sep 2021 12:27:09 GMT</pubDate></item></channel></rss>
