<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core2 schematics]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">yesterday I got my first Core2 and it's very amazing. I like the new touch screen.</p>
<p dir="auto">I like to use it with ESP-IDF and so I am searching for some hardware information to<br />
program the software. I downloaded the overall schematic and I didn't found details of</p>
<li>FT6336U</li>
<li>ILI9342C.</li>
<p dir="auto">I found all data sheets, thank you.</p>
<p dir="auto">Also I found a small box marked with "LCD" at the overall schematic and I saw the MISO/MOSI/SCK-Pins.<br />
Is there some more information?</p>
<p dir="auto">I guess</p>
<li>
<p dir="auto">I cann't use interrupt of FT6363U and</p>
</li>
<li>
<p dir="auto">I cann't read back the pixel value of the ILI9342C to control lots of WS8212.</p>
</li>
]]></description><link>https://community.m5stack.com/topic/2290/core2-schematics</link><generator>RSS for Node</generator><lastBuildDate>Sun, 03 May 2026 09:05:54 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2290.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 10 Sep 2020 04:21:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core2 schematics on Fri, 18 Sep 2020 13:55:27 GMT]]></title><description><![CDATA[<p dir="auto">Hi Uwe</p>
<p dir="auto">You are welcome!</p>
<p dir="auto">I am using Visual Studio Code / PlatformIO (<code>platform: espressif32; framework: arduino</code>). Which is similar to the Arduino IDE.</p>
<p dir="auto">Cheers<br />
]]></description><link>https://community.m5stack.com/post/10130</link><guid isPermaLink="true">https://community.m5stack.com/post/10130</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 18 Sep 2020 13:55:27 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 schematics on Fri, 18 Sep 2020 12:37:59 GMT]]></title><description><![CDATA[<p dir="auto">Hello Felix,</p>
<p dir="auto">thanks for your help. I saw the INT-line.</p>
<p dir="auto">Do you program with Arduino or ESP-IDF or ..?</p>
<p dir="auto">Thanks,<br />
Uwe</p>
]]></description><link>https://community.m5stack.com/post/10129</link><guid isPermaLink="true">https://community.m5stack.com/post/10129</guid><dc:creator><![CDATA[sheepDog]]></dc:creator><pubDate>Fri, 18 Sep 2020 12:37:59 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 schematics on Mon, 14 Sep 2020 15:20:17 GMT]]></title><description><![CDATA[<p dir="auto">Hello Uwe</p>
<p dir="auto">In the overall schematics at the bottom right you'll see <code>CTP_2.0Inch</code> which is the touch IC and the <code>INT</code> line is labelled with GPIO39.</p>
<p dir="auto">GPIO39 is also set as input in the <code>touch::begin()</code> function of the <code>touch.c</code> source file: <a href="https://github.com/m5stack/M5Core2/blob/master/src/touch.cpp" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5Core2/blob/master/src/touch.cpp</a></p>
]]></description><link>https://community.m5stack.com/post/10083</link><guid isPermaLink="true">https://community.m5stack.com/post/10083</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 14 Sep 2020 15:20:17 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 schematics on Mon, 14 Sep 2020 14:10:35 GMT]]></title><description><![CDATA[<p dir="auto">Hello Felix,</p>
<p dir="auto">thank you for the GPIO39 information.  How did you get the information? Try and error?</p>
Uwe</p>
]]></description><link>https://community.m5stack.com/post/10081</link><guid isPermaLink="true">https://community.m5stack.com/post/10081</guid><dc:creator><![CDATA[sheepDog]]></dc:creator><pubDate>Mon, 14 Sep 2020 14:10:35 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 schematics on Mon, 14 Sep 2020 10:32:03 GMT]]></title><description><![CDATA[<p dir="auto">Hello Uwe</p>
<p dir="auto">Thanks, I found a data sheet for FT5x06 which seems similar enough and with that I figured out how to put touch IC into hibernation mode - writing <code>0x03</code> into register <code>0xA5</code> (PWR_MODE) does the trick.</p>
<p dir="auto">BTW: I am using FT6363U interrupt - it's connected to GPIO39. You might want to play with the two available modes: trigger mode (<code>0x01</code> - default) and polling mode (<code>0x00</code>) which can be set via register <code>0xA4</code> (G_MODE).</p>
]]></description><link>https://community.m5stack.com/post/10077</link><guid isPermaLink="true">https://community.m5stack.com/post/10077</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 14 Sep 2020 10:32:03 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 schematics on Fri, 11 Sep 2020 03:46:23 GMT]]></title><description><![CDATA[<p dir="auto">Hello Felix,</p>
<p dir="auto">you are right. I downloaded a long data sheet for the FT6336U from an other source. These data sheet consist 30 pages, at M5Stack you can load only 10 pages. Only the first few pages are the same at both sources.</p>
Uwe</p>
]]></description><link>https://community.m5stack.com/post/10027</link><guid isPermaLink="true">https://community.m5stack.com/post/10027</guid><dc:creator><![CDATA[sheepDog]]></dc:creator><pubDate>Fri, 11 Sep 2020 03:46:23 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 schematics on Thu, 10 Sep 2020 09:30:33 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/sheepdog" aria-label="Profile: sheepDog">@<bdi>sheepDog</bdi></a></p>
<p dir="auto">I was wondering, does the data sheet you found for FT6336U contain a description of the registers and their contents? The data sheet linked from M5Stack page doesn't describe the registers, but it talks about different operation modes. I am particularly interested in how to activate hibernation mode.</p>
]]></description><link>https://community.m5stack.com/post/10026</link><guid isPermaLink="true">https://community.m5stack.com/post/10026</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 10 Sep 2020 09:30:33 GMT</pubDate></item></channel></rss>
