<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[&quot;Timed out waiting for packet header&quot;]]></title><description><![CDATA[<p dir="auto">Hi<br />
Trying to follow an official M5 tuto, I want to upload the arduino code to the Fire board.<br />
I get a time out error. Full message :<br />
Arduino : 1.8.1 (Windows 7), Carte : "M5Stack-FIRE, Enabled, Default (2 x 6.5 MB app, 3.6 MB SPIFFS), 115200, None"</p>
<p dir="auto"><a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a> v2.6<br />
Serial port COM26<br />
Connecting........<em><strong><strong>.....</strong></strong></em>.....<em><strong><strong>.....</strong></strong></em>.....<em><strong><strong>.....</strong></strong></em>.....____Une erreur est survenue lors du transfert du croquis<br />
_</p>
<p dir="auto">A fatal error occurred: Failed to connect to ESP32: <strong>Timed out waiting for packet header</strong></p>
<p dir="auto">I tried many baudrates, with no luck<br />
Some people say it is because we need to hold-down the “BOOT/FLASH” button while uploading ...is there a simple way to do it with the Fire board ?</p>
]]></description><link>https://community.m5stack.com/topic/2297/timed-out-waiting-for-packet-header</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 08:41:47 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2297.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 11 Sep 2020 07:04:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to &quot;Timed out waiting for packet header&quot; on Fri, 11 Sep 2020 15:47:09 GMT]]></title><description><![CDATA[<h1>Getting worse...M5burner won't even erase now</h1>
<h1>Erase now</h1>
<p dir="auto"><a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a> v2.5.0<br />
Connecting........_<br />
Detecting chip type...</p>
<p dir="auto">It stays there for ever<br />
Pliz someone help me ?!</p>
]]></description><link>https://community.m5stack.com/post/10053</link><guid isPermaLink="true">https://community.m5stack.com/post/10053</guid><dc:creator><![CDATA[F3l1x]]></dc:creator><pubDate>Fri, 11 Sep 2020 15:47:09 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Timed out waiting for packet header&quot; on Fri, 11 Sep 2020 13:38:19 GMT]]></title><description><![CDATA[<p dir="auto">Oups...not solved at all<br />
It did it again and again. Won't flash from arduino IDE</p>
<p dir="auto">Arduino : 1.8.1 (Windows 7), Carte : "M5Stack-FIRE, Enabled, Default (2 x 6.5 MB app, 3.6 MB SPIFFS), 115200, Debug"</p>
<p dir="auto">[ ]<br />
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\2.6.1/esptool.exe --chip esp32 --port COM26 --baud 115200 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/partitions/boot_app0.bin 0x1000 C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4/tools/sdk/bin/bootloader_dio_80m.bin 0x10000 C:\Users\xxx\AppData\Local\Temp\arduino_build_345911/FireScreen.ino.bin 0x8000 C:\Users\xxx\AppData\Local\Temp\arduino_build_345911/FireScreen.ino.partitions.bin<br />
Connecting........___<strong>.....</strong><br />
Chip is ESP32D0WDQ6 (revision 1)<br />
MAC: a4:cf:12:44:6d:d0<br />
Uploading stub...<br />
Running stub...<br />
Stub running...<br />
Warning: Could not auto-detect Flash size (FlashID=0xffffff, SizeID=0xff), defaulting to 4MB<br />
Compressed 8192 bytes to 47...</p>
<p dir="auto">A fatal error occurred: Timed out waiting for packet content</p>
<p dir="auto">I did erase and reflash firmware...fail again<br />
I'm getting mad at this Fire thing<br />
So promising and so disappointing!</p>
]]></description><link>https://community.m5stack.com/post/10050</link><guid isPermaLink="true">https://community.m5stack.com/post/10050</guid><dc:creator><![CDATA[F3l1x]]></dc:creator><pubDate>Fri, 11 Sep 2020 13:38:19 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Timed out waiting for packet header&quot; on Fri, 11 Sep 2020 10:07:57 GMT]]></title><description><![CDATA[<p dir="auto">Thanx...everything back to normal<br />
Is there a way to mark topic as [solved] ?</p>
]]></description><link>https://community.m5stack.com/post/10044</link><guid isPermaLink="true">https://community.m5stack.com/post/10044</guid><dc:creator><![CDATA[F3l1x]]></dc:creator><pubDate>Fri, 11 Sep 2020 10:07:57 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Timed out waiting for packet header&quot; on Fri, 11 Sep 2020 08:43:39 GMT]]></title><description><![CDATA[<p dir="auto">try to remove the FIRE battery bottom</p>
<p dir="auto">try to erase the flash by M5Burner</p>
<p dir="auto">then try upload the UIFlow firmware agian.</p>
<p dir="auto">if still don't work.   you could contact the store</p>
]]></description><link>https://community.m5stack.com/post/10042</link><guid isPermaLink="true">https://community.m5stack.com/post/10042</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 11 Sep 2020 08:43:39 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Timed out waiting for packet header&quot; on Sun, 13 Sep 2020 18:15:56 GMT]]></title><description><![CDATA[<p dir="auto">Sooooo...<br />
The arduino code did upload - I don't know why!<br />
But the program did not show anything so I tried to edit it, and now it won't upload.<br />
So I thought it was something about the USB mode. Unfortunately, I don't have the setup option anymore<br />
So I tried burning the 1.6.2 firmware again...M5Burner fails with this message:<br />
<strong>Chip is ESP32D0WDQ6 (revision 1)<br />
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse<br />
A fatal error occured: File C:\Users\zzz\Downloads\M5Burner\packages\fw\other\wifi.bin (length 100) at  offset 6287360 will not fit in 4194304 bytes of flash. Use --flash-size argument, or change flashing address</strong><br />
<strong>Burned failed</strong></p>
<p dir="auto">I feel so stupid...</p>
]]></description><link>https://community.m5stack.com/post/10041</link><guid isPermaLink="true">https://community.m5stack.com/post/10041</guid><dc:creator><![CDATA[F3l1x]]></dc:creator><pubDate>Sun, 13 Sep 2020 18:15:56 GMT</pubDate></item></channel></rss>
