<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[SOLVED] Arduino IDE on Windows won&#x27;t flash]]></title><description><![CDATA[<p dir="auto">Hi<br />
I had problems using arduino IDE with a Fire board on a windows 7 laptop (got time out error)<br />
I tried many solutions, including  updating the COM driver, using command line esptool, or installing OTA on arduino IDE<br />
Every solution does work ONCE, the first time, and then won't work anymore<br />
It is the same on a windows 10 desktop, but I found out that everything was ok on my old Debian laptop<br />
So my question is : is arduino  IDE really usable on windows machines ? Is there a "hack" I should know?</p>
]]></description><link>https://community.m5stack.com/topic/2303/solved-arduino-ide-on-windows-won-t-flash</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:06:15 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2303.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 13 Sep 2020 18:26:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [SOLVED] Arduino IDE on Windows won&#x27;t flash on Tue, 15 Sep 2020 05:15:36 GMT]]></title><description><![CDATA[<p dir="auto">No drivers needed for stickC and atom on linux, but you need to know what you're doing to allow access to the usb, e.g. add permission for non root user, this could be especially tricky if using linux in a virtual machine.</p>
]]></description><link>https://community.m5stack.com/post/10088</link><guid isPermaLink="true">https://community.m5stack.com/post/10088</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Tue, 15 Sep 2020 05:15:36 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] Arduino IDE on Windows won&#x27;t flash on Mon, 14 Sep 2020 10:31:52 GMT]]></title><description><![CDATA[<p dir="auto">Thanx a lot, it works!</p>
<p dir="auto">What if I use windows 10 and WSL (linux inside windows) ? Will I avoid driver problems ?</p>
]]></description><link>https://community.m5stack.com/post/10074</link><guid isPermaLink="true">https://community.m5stack.com/post/10074</guid><dc:creator><![CDATA[F3l1x]]></dc:creator><pubDate>Mon, 14 Sep 2020 10:31:52 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] Arduino IDE on Windows won&#x27;t flash on Sun, 13 Sep 2020 19:48:36 GMT]]></title><description><![CDATA[<p dir="auto">No, its the com port driver. Windows and OSX insist on users using the included broken driver and so kill the driver from the download page.<br />
The most optimal way to get things to work involves several "Cold Starts" of computers. A "Cold Start is where the hardware is powered off and left for a minimum of 3 mins to allow the capacitors in the ram to discharge, fully wiping the ram of retained data.</p>
<p dir="auto">1, Delete existing com port driver,<br />
2, Switch off and cold start machine.<br />
3, Install driver,<br />
4,  Switch off and cold start machine.<br />
5, Connect M5Stack cores and check the device managers for errors and that devices are recognised.<br />
6,  Switch off and cold start machine.<br />
7, wait for machine to finish loading (give this 5 to ten minutes), then try connecting M5Stack BEFORE loading Arduino.</p>
<p dir="auto">IF you reinstall arduino or any other IDE/Programming environment,  you MUST  Switch off and cold start machine before starting to program.</p>
<p dir="auto">This is not a flawless method but is the most reliable method to get the driver to work on Windows and OSX!</p>
]]></description><link>https://community.m5stack.com/post/10073</link><guid isPermaLink="true">https://community.m5stack.com/post/10073</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 13 Sep 2020 19:48:36 GMT</pubDate></item></channel></rss>
