<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bus Connector size? (not 2.54)]]></title><description><![CDATA[<p dir="auto">What is the actual size of the bus header as it is too small for my Dupont 2.54mm pins?</p>
]]></description><link>https://community.m5stack.com/topic/232/bus-connector-size-not-2-54</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 13:17:41 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/232.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 17 Jun 2018 12:12:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bus Connector size? (not 2.54) on Wed, 20 Jun 2018 19:24:52 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a>,</p>
<p dir="auto">I gather you are talking about the internal MBUS GPIO pins - that connect the modules together.</p>
<p dir="auto">The pin pitch - distance between the pins - is 2.54 but the pins are height reduced compared to those found on a standard GPIO header - too SHORT for Dupont connectors to attach.</p>
<p dir="auto">The MBUS pins are intentionally height reduced in order to minimise the overall height of the M5Stack.</p>
<p dir="auto">It is possible to source a third party full height 30 pin GPIO header if needed, or you can make one using a GPIO for Arduino or Raspi. You could get a PCB made to go with it, based on the files available on github, see <a href="https://github.com/PartsandCircuits/M5Stack-3DPrintFiles" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/1124</link><guid isPermaLink="true">https://community.m5stack.com/post/1124</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Wed, 20 Jun 2018 19:24:52 GMT</pubDate></item></channel></rss>
