<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Disconnect speaker]]></title><description><![CDATA[<p dir="auto">Hi! My m5stack fire is making some loud white noise and I can't turn it off even with<br />
p = Pin(25)<br />
dac0 = DAC(p)<br />
dac0.write(0)</p>
<p dir="auto">Can I disconnect the speak safely if I don't ever intend to use it? Like cut the cable and remove it?</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://community.m5stack.com/topic/2325/disconnect-speaker</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:45:52 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2325.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 29 Sep 2020 00:48:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Disconnect speaker on Tue, 29 Sep 2020 19:22:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tialm" aria-label="Profile: tialm">@<bdi>tialm</bdi></a></p>
<p dir="auto">Or you can try this as well:</p>
<p dir="auto"><a href="https://community.m5stack.com/topic/367/mod-to-programmatically-disable-speaker-whine-hiss">https://community.m5stack.com/topic/367/mod-to-programmatically-disable-speaker-whine-hiss</a></p>
]]></description><link>https://community.m5stack.com/post/10213</link><guid isPermaLink="true">https://community.m5stack.com/post/10213</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Tue, 29 Sep 2020 19:22:30 GMT</pubDate></item><item><title><![CDATA[Reply to Disconnect speaker on Tue, 29 Sep 2020 01:09:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tialm" aria-label="Profile: tialm">@<bdi>tialm</bdi></a> make sure you don't want to use it. remove the bottom you could see the speaker cable. you could cut the cable remove it.</p>
]]></description><link>https://community.m5stack.com/post/10208</link><guid isPermaLink="true">https://community.m5stack.com/post/10208</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Tue, 29 Sep 2020 01:09:31 GMT</pubDate></item></channel></rss>
