<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Atom Matrix auto-run?]]></title><description><![CDATA[<p dir="auto">I cannot get a program to autostart in an Atom Matrix.  After I switch modes with button/reset and release at purple, the screen turns black and stays black through reset and power on.  I also tried naming it "main", and also "<a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow ugc">main.py</a>", but no luck.</p>
<p dir="auto">What am I doing wrong?</p>
David</p>
]]></description><link>https://community.m5stack.com/topic/2335/atom-matrix-auto-run</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 03:33:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2335.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Oct 2020 17:40:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Atom Matrix auto-run? on Wed, 14 Oct 2020 02:19:08 GMT]]></title><description><![CDATA[<p dir="auto">in the FS root path has already had <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow ugc">main.py</a> file you could modify it. when you select the app mode(purple) <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow ugc">main.py</a> will be exec.</p>
<p dir="auto">if you are use UIFlow, you need to download the program, not just exec it. then it will auto setting this program for auto-start running.</p>
<p dir="auto">if still not work, pls check the serial log</p>
]]></description><link>https://community.m5stack.com/post/10272</link><guid isPermaLink="true">https://community.m5stack.com/post/10272</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 14 Oct 2020 02:19:08 GMT</pubDate></item></channel></rss>
