<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can the Atom accept external regulated 5V power?]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I was wondering if the Atom can be powered by an external regulated 5V power source through the 5V pin or Grove connector 5V pin. I understand some other popular boards can allow this (such as the Arduinos), but I couldn't find any documentation on whether or not the Atom supports this too.</p>
<p dir="auto">As I'm still a novice when it comes to electronics, I'm afraid of trying this out myself and risking damaging my Atom. Also, for space and cost reasons I want to avoid using the USB C connector to provide power.</p>
]]></description><link>https://community.m5stack.com/topic/2341/can-the-atom-accept-external-regulated-5v-power</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:29:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2341.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 17 Sep 2020 21:16:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can the Atom accept external regulated 5V power? on Sun, 18 Oct 2020 12:48:40 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/koreaneggcoffee" aria-label="Profile: koreanEggCoffee">@<bdi>koreanEggCoffee</bdi></a></p>
<p dir="auto">yes, that is possible - I am powering my M5Atom this way.</p>
<p dir="auto">However please note: There is no protection against wrong polarity so please be careful not to accidentally swapping 5 volts and GND.</p>
<p dir="auto">I also suggest you disconnect the external 5 volts before connecting USB-C. Or in other words only connect one power source at the same time.</p>
<p dir="auto">Please also refer to the M5Atom schematics which outlines the 5 volts connections between USB, 5v pin, Groove, LEDs and 3.3 volts regulator.</p>
<p dir="auto"><a href="https://docs.m5stack.com/#/en/core/atom_matrix" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/core/atom_matrix</a></p>
<p dir="auto">Cheers<br />
]]></description><link>https://community.m5stack.com/post/10384</link><guid isPermaLink="true">https://community.m5stack.com/post/10384</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 18 Oct 2020 12:48:40 GMT</pubDate></item></channel></rss>
