<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[no module named m5stack_ui]]></title><description><![CDATA[<p dir="auto">It has taken me many hours to get UIFlow to 'partially' work.</p>
<p dir="auto">I can finally connect through the windows based UI flow. Through USB I can upload programs and those work. hooray!</p>
<p dir="auto">My current problem is when I switch to the internet version. I am able to connect to wifi and even connect to my device using the internet version. But when I try to press the play button on the internet UI flow I get this error:</p>
<p dir="auto">"no module named m5stack_ui"</p>
<p dir="auto">When I press the detail button it says:</p>
<p dir="auto">file "&lt;string&gt;", line 2, in &lt;module&gt;<br />
ImportError: no module named m5stack_ui</p>
<p dir="auto">Do I need to install something to fix this?</p>
]]></description><link>https://community.m5stack.com/topic/2342/no-module-named-m5stack_ui</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:39:57 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2342.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 18 Sep 2020 19:20:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to no module named m5stack_ui on Tue, 21 Jun 2022 03:17:40 GMT]]></title><description><![CDATA[<p dir="auto">This worked for me...  <a href="https://community.m5stack.com/topic/3861/solved-importerror-no-module-named-m5stack_ui">https://community.m5stack.com/topic/3861/solved-importerror-no-module-named-m5stack_ui</a></p>
]]></description><link>https://community.m5stack.com/post/17779</link><guid isPermaLink="true">https://community.m5stack.com/post/17779</guid><dc:creator><![CDATA[JDZAWODNIAK]]></dc:creator><pubDate>Tue, 21 Jun 2022 03:17:40 GMT</pubDate></item><item><title><![CDATA[Reply to no module named m5stack_ui on Wed, 20 Apr 2022 18:41:18 GMT]]></title><description><![CDATA[<p dir="auto">What Controller are you running?</p>
]]></description><link>https://community.m5stack.com/post/17227</link><guid isPermaLink="true">https://community.m5stack.com/post/17227</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 20 Apr 2022 18:41:18 GMT</pubDate></item><item><title><![CDATA[Reply to no module named m5stack_ui on Wed, 20 Apr 2022 15:11:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> Can you please help here?<br />
I've flashed 1.9.4-en and 1.9.5-en versions without luck...</p>
<p dir="auto">It's only happening if I "run" the program. In both versions if I do the "download" then screen just go blank.</p>
]]></description><link>https://community.m5stack.com/post/17225</link><guid isPermaLink="true">https://community.m5stack.com/post/17225</guid><dc:creator><![CDATA[ciconde]]></dc:creator><pubDate>Wed, 20 Apr 2022 15:11:20 GMT</pubDate></item><item><title><![CDATA[Reply to no module named m5stack_ui on Wed, 20 Apr 2022 14:10:42 GMT]]></title><description><![CDATA[<p dir="auto">Same problem here</p>
<p dir="auto">No solution yet?</p>
]]></description><link>https://community.m5stack.com/post/17224</link><guid isPermaLink="true">https://community.m5stack.com/post/17224</guid><dc:creator><![CDATA[ciconde]]></dc:creator><pubDate>Wed, 20 Apr 2022 14:10:42 GMT</pubDate></item><item><title><![CDATA[Reply to no module named m5stack_ui on Sat, 09 Jan 2021 01:03:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zenman" aria-label="Profile: zenman">@<bdi>zenman</bdi></a> I have the same error in my first test, Not a good start M5stack</p>
]]></description><link>https://community.m5stack.com/post/11735</link><guid isPermaLink="true">https://community.m5stack.com/post/11735</guid><dc:creator><![CDATA[wmantilla]]></dc:creator><pubDate>Sat, 09 Jan 2021 01:03:11 GMT</pubDate></item></channel></rss>
