<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 Stick C :  &quot;Guru Meditation Error: Core  0 panic&#x27;ed (LoadProhibited)&quot;]]></title><description><![CDATA[<p dir="auto">Using Arduino 1.8.12  ,  Library: M5StickC 0.2.0</p>
<p dir="auto">My M5Sticks run anywhere from 2days to 3 weeks and then crash.<br />
The crash typically happens right after some WiFi networking call.<br />
For example:<br />
crash after:   http.begin(g_wClient , g_cHttpCmd);<br />
or crash after :    iRSSI = WiFi.RSSI();</p>
<p dir="auto">After the crash, the M5 Stick C does not automatically reboot , which I believe it should</p>
<p dir="auto">Attached is the debug output:<br />
21:16:28.890 -&gt; Guru Meditation Error: Core  0 panic'ed (IllegalInstruction). Exception was unhandled.<br />
21:16:28.890 -&gt; Memory dump at 0x40082868: 03adf784 c0079ea5 40082920<br />
21:16:28.890 -&gt; Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.<br />
21:16:28.924 -&gt; Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.<br />
21:16:28.959 -&gt; Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.<br />
21:16:28.993 -&gt; Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.<br />
21:16:29.027 -&gt; Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.<br />
21:16:29.060 -&gt; Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.<br />
21:16:29.094 -&gt; Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.<br />
21:16:29.128 -&gt; Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.<br />
21:16:29.163 -&gt; Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.<br />
21:16:29.163 -&gt; Guru Meditation Error: Core  0</p>
]]></description><link>https://community.m5stack.com/topic/2345/m5-stick-c-guru-meditation-error-core-0-panic-ed-loadprohibited</link><generator>RSS for Node</generator><lastBuildDate>Mon, 04 May 2026 15:26:28 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2345.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 07 Oct 2020 11:55:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 Stick C :  &quot;Guru Meditation Error: Core  0 panic&#x27;ed (LoadProhibited)&quot; on Mon, 09 Nov 2020 08:00:38 GMT]]></title><description><![CDATA[<p dir="auto">In this situation, we haven't met. our all firmware is used 240MHz default. maybe you could check it does related to your program.</p>
]]></description><link>https://community.m5stack.com/post/10661</link><guid isPermaLink="true">https://community.m5stack.com/post/10661</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 09 Nov 2020 08:00:38 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Stick C :  &quot;Guru Meditation Error: Core  0 panic&#x27;ed (LoadProhibited)&quot; on Sat, 07 Nov 2020 10:22:18 GMT]]></title><description><![CDATA[<p dir="auto">Reduced CPU from 240MHz to 80MHz ----Problem seems to be gone</p>
<p dir="auto">Hmmmmm....   shaky hardware?</p>
]]></description><link>https://community.m5stack.com/post/10637</link><guid isPermaLink="true">https://community.m5stack.com/post/10637</guid><dc:creator><![CDATA[heleb]]></dc:creator><pubDate>Sat, 07 Nov 2020 10:22:18 GMT</pubDate></item></channel></rss>
