<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core2 + Face RFID cannot get work]]></title><description><![CDATA[<p dir="auto">I bougth Core2 + Faced RFID. With FlowUI I can get all work, but I want to make some Arduino code, because want to have faster boot, FlowUI have own boot logo etc.</p>
<p dir="auto">If I use M5Stack library Core2 wont boot.<br />
If I use this code wont work: <a href="https://github.com/m5stack/M5Stack/blob/master/examples/Face/RFID/RFID.ino" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5Stack/blob/master/examples/Face/RFID/RFID.ino</a></p>
<p dir="auto">Only M5Core2.h working, but cannot get RFID to work.</p>
<p dir="auto">Have anyone tried this?</p>
]]></description><link>https://community.m5stack.com/topic/2347/core2-face-rfid-cannot-get-work</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 23:34:05 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2347.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 08 Oct 2020 17:13:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core2 + Face RFID cannot get work on Wed, 04 Aug 2021 02:19:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jvaleri" aria-label="Profile: jvaleri">@<bdi>jvaleri</bdi></a></p>
<p dir="auto">Thanks for posting this link!</p>
]]></description><link>https://community.m5stack.com/post/14572</link><guid isPermaLink="true">https://community.m5stack.com/post/14572</guid><dc:creator><![CDATA[markran]]></dc:creator><pubDate>Wed, 04 Aug 2021 02:19:32 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 + Face RFID cannot get work on Wed, 09 Jun 2021 06:58:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jvaleri" aria-label="Profile: jvaleri">@<bdi>jvaleri</bdi></a> what files did you use from that github repository? These ones:<br />
escornafid_para_m5stackcore2/firmware_escornabot/arduino_modificado_MFRC522-1.6.2/Escornabot/MFRC522Interface.* or the zip file?</p>
]]></description><link>https://community.m5stack.com/post/14055</link><guid isPermaLink="true">https://community.m5stack.com/post/14055</guid><dc:creator><![CDATA[limar]]></dc:creator><pubDate>Wed, 09 Jun 2021 06:58:48 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 + Face RFID cannot get work on Thu, 18 Feb 2021 10:17:48 GMT]]></title><description><![CDATA[<p dir="auto">I found an example that fits your needs. It is called 'escornaFID'  <a href="https://github.com/avilmaru/escornafid_para_m5stackcore2" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/avilmaru/escornafid_para_m5stackcore2</a></p>
<p dir="auto">They use a modified library, not the one you find in Arduino Repository, and works like a charm....</p>
]]></description><link>https://community.m5stack.com/post/12570</link><guid isPermaLink="true">https://community.m5stack.com/post/12570</guid><dc:creator><![CDATA[jvaleri]]></dc:creator><pubDate>Thu, 18 Feb 2021 10:17:48 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 + Face RFID cannot get work on Thu, 03 Dec 2020 08:43:38 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/antzaro" aria-label="Profile: antzaro">@<bdi>antzaro</bdi></a></p>
<p dir="auto">I think you'll first need to remove the dark grey bottom plate of the M5Core2 which is held in place by four screws. Please be careful when doing so as the battery is attached (double sided tape) to the bottom plate while its wire is connected to the M5Core2 main PCB using a small connector. Without the bottom plate the M5Core2 should fit onto the Face RFID.</p>
]]></description><link>https://community.m5stack.com/post/10997</link><guid isPermaLink="true">https://community.m5stack.com/post/10997</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 03 Dec 2020 08:43:38 GMT</pubDate></item><item><title><![CDATA[Reply to Core2 + Face RFID cannot get work on Wed, 02 Dec 2020 22:21:31 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">How can I connect a core2 to a faces II with an RFID?<br />
The faces II male connector is too short to plug into the female connector inside the core2.<br />
<img src="/assets/uploads/files/1606947681668-core2-faces-ii-resized.jpeg" alt="0_1606947678710_Core2 - Faces II.jpeg" class=" img-fluid img-markdown" /><br />
Thank you.!</p>
]]></description><link>https://community.m5stack.com/post/10995</link><guid isPermaLink="true">https://community.m5stack.com/post/10995</guid><dc:creator><![CDATA[antzaro]]></dc:creator><pubDate>Wed, 02 Dec 2020 22:21:31 GMT</pubDate></item></channel></rss>
