<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Flash m5go with the regular m5stack firmware?]]></title><description><![CDATA[<p dir="auto">Just got my m5go and while it looks pretty cool, the web interface isn't really good, and I can't seem to upload my programs. Is it possible to flash the regular m5stack firmware and code it via m5cloud? Will I be able to use the grove sensors and internal sensors using the same code? Thanks!</p>
]]></description><link>https://community.m5stack.com/topic/235/flash-m5go-with-the-regular-m5stack-firmware</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 01:07:09 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/235.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 Jun 2018 22:02:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Flash m5go with the regular m5stack firmware? on Wed, 20 Jun 2018 18:48:30 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/lastcaress" aria-label="Profile: lastcaress">@<bdi>lastcaress</bdi></a>,</p>
<p dir="auto">You should be able to flash the standard M5Stack firmware onto the M5GO  (you may need to use the "Erase" function on the ESP Flash Downloader Tool first).</p>
<p dir="auto">If you want to use M5Cloud you will need to load the M5Cloud firmware onto the M5Stack - it is available <a href="https://github.com/m5stack/M5Cloud" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
<p dir="auto">Not sure if you will be able to use the sensors using the same code - it depends how it is all setup.</p>
]]></description><link>https://community.m5stack.com/post/1122</link><guid isPermaLink="true">https://community.m5stack.com/post/1122</guid><dc:creator><![CDATA[JJ]]></dc:creator><pubDate>Wed, 20 Jun 2018 18:48:30 GMT</pubDate></item></channel></rss>
