<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SD card does not work with M5Stack Faces Kit]]></title><description><![CDATA[<p dir="auto">Access to the SD card is not possible. However, if I disconnect the M5Stack module from the Faces-Base, access to the SD card works.</p>
<p dir="auto">See also: <a href="https://github.com/tobozo/M5Stack-SD-Updater/issues/146" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/tobozo/M5Stack-SD-Updater/issues/146</a></p>
<p dir="auto">The kit was ordered and delivered from Conrad. After the SD card did not work, I complained about the entire Faces kit and received an exchange. But this kit also has the same problem.</p>
]]></description><link>https://community.m5stack.com/topic/2354/sd-card-does-not-work-with-m5stack-faces-kit</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 04:16:05 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2354.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Oct 2020 12:52:54 GMT</pubDate><ttl>60</ttl></channel></rss>
