<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickV AI Camera - power on&#x2F;off via groove connector pin]]></title><description><![CDATA[<p dir="auto">Hello!<br />
Is it possible to power on/off the M5StickV via one of the pins exposed in the groove connection ( 34 &amp; 35 ) ?<br />
Should I remap the pins using the fpioa_manager somehow (I'm using micro python code) ? I'm planning to use the module in permanent installation that should be turned on/off in programmed schedule rather than by manually pressing the power button.  Thanks for any tips !</p>
]]></description><link>https://community.m5stack.com/topic/2360/m5stickv-ai-camera-power-on-off-via-groove-connector-pin</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 04:16:08 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2360.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Oct 2020 14:31:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickV AI Camera - power on&#x2F;off via groove connector pin on Thu, 05 Nov 2020 08:17:19 GMT]]></title><description><![CDATA[<p dir="auto">You can use any pin to control the device to sleep.<br />
But only the power button can wake it up.<br />
You can configure the AXP192 register to make the device enter the sleep state.</p>
<p dir="auto"><a href="https://github.com/MarsTechHAN/MaixPy/blob/master/projects/maixpy_m5stickv/builtin_py/pmu.py" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MarsTechHAN/MaixPy/blob/master/projects/maixpy_m5stickv/builtin_py/pmu.py</a></p>
]]></description><link>https://community.m5stack.com/post/10619</link><guid isPermaLink="true">https://community.m5stack.com/post/10619</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 05 Nov 2020 08:17:19 GMT</pubDate></item></channel></rss>
