<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Fire won’t connect to IPhone hotspot]]></title><description><![CDATA[<p dir="auto">I can’t get my M5 to connect to my iPhone personal hotspot on my XSMax. I’m not connected to a WiFi connection, my hotspot name is Kelly, no spaces or anything, I put the M5 in the select Wi-Fi Ap mode and go to the IP address shown on the screen and the connection page comes up. My hotspot isn’t listed which I think is probably my first clue it’s not going to work and then I click the other box and type in Kelly and the password, but it will not connect. I plan to try it with anothe lr hotspot if I get a chance. I thought I had wrote my program where if it didn’t find a WiFi connection, it would not matter, but I guess not.</p>
]]></description><link>https://community.m5stack.com/topic/2362/m5stack-fire-won-t-connect-to-iphone-hotspot</link><generator>RSS for Node</generator><lastBuildDate>Mon, 04 May 2026 17:15:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2362.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 Oct 2020 12:04:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack Fire won’t connect to IPhone hotspot on Fri, 08 Jul 2022 09:31:36 GMT]]></title><description><![CDATA[<p dir="auto">Check the WiFi frequency band. ESP32 is only compatible to 2.4GHz WiFi networks. Some iPhone use 5GHz by default but there is a compatibility mode for switching down to 2.4GHz.</p>
]]></description><link>https://community.m5stack.com/post/17950</link><guid isPermaLink="true">https://community.m5stack.com/post/17950</guid><dc:creator><![CDATA[holofloh]]></dc:creator><pubDate>Fri, 08 Jul 2022 09:31:36 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Fire won’t connect to IPhone hotspot on Fri, 08 Jul 2022 01:35:43 GMT]]></title><description><![CDATA[<p dir="auto">Hi, I have been looking all over and not able to solve it yet, I have a Fire, and will not connect to wifi, I have tried no spaces, no battery, etc, no luck.<br />
I have tried different routers and still not working.<br />
only once I had been able to connect to wifi, very long ago, I can access it as AP, but no way to get it to connect to a wifi network.</p>
<p dir="auto">any help?<br />
thanks</p>
]]></description><link>https://community.m5stack.com/post/17947</link><guid isPermaLink="true">https://community.m5stack.com/post/17947</guid><dc:creator><![CDATA[neptuno]]></dc:creator><pubDate>Fri, 08 Jul 2022 01:35:43 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Fire won’t connect to IPhone hotspot on Sun, 18 Oct 2020 22:14:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> That did the trick! Thank you! I was able to get it connected without the battery. So can I attach the battery now?</p>
]]></description><link>https://community.m5stack.com/post/10395</link><guid isPermaLink="true">https://community.m5stack.com/post/10395</guid><dc:creator><![CDATA[ksprayberry]]></dc:creator><pubDate>Sun, 18 Oct 2020 22:14:21 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Fire won’t connect to IPhone hotspot on Fri, 16 Oct 2020 10:07:54 GMT]]></title><description><![CDATA[<p dir="auto">your other device connect the hotspot is normal?</p>
<p dir="auto">maybe you could try to remove the battery bottom.  then try again.</p>
]]></description><link>https://community.m5stack.com/post/10351</link><guid isPermaLink="true">https://community.m5stack.com/post/10351</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 16 Oct 2020 10:07:54 GMT</pubDate></item></channel></rss>
