<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core 0 panic&#x27;ed, but reboot does not happen]]></title><description><![CDATA[<p dir="auto">I get the occasional core 0 related freezes of M5 Stick C.<br />
Using the latest Arduino IDE with latest M5 libs.</p>
<p dir="auto">I did program a watchdog timer, which works, except when the core 0 error happens.</p>
<p dir="auto">Once the unit hangs it gets wamer than usual and consumes about 100ms. The unit is no longer visible on the network, and will not respond to button presses (except power off button)</p>
<p dir="auto">How can I fix this?  (Stick needs to reboot on core 0 error)</p>
<p dir="auto">Thanks !</p>
<p dir="auto">----------------------------------------  Log -----<br />
SSID: Jackdog-73dBm (54% )<br />
OFF_Display<br />
FreeHeap=240924<br />
sunnyboy<br />
<a href="http://sunnyboy/solar_api/v1/GetPowerFlowRealtimeData.fcgi" target="_blank" rel="noopener noreferrer nofollow ugc">http://sunnyboy/solar_api/v1/GetPowerFlowRealtimeData.fcgi</a><br />
Fronius:BEFORE  g_ihttpFronius = http.GET()<br />
Fronius:AFTER  g_ihttpFronius = http.GET()<br />
g_ihttpFronius=-1<br />
Guru Meditation Error: Core  0 panic'ed (IllegalInstruction). Exception was unhandled.<br />
Memory dump at 0x40082868: 03adf784 c0079ea5 40082920<br />
Memory dump at 0x400808dc: 3f4183b4 3f418440 3f4183d0<br />
Guru Meditation Er</p>
<p dir="auto">----------------------------- end log--------------------------------</p>
]]></description><link>https://community.m5stack.com/topic/2382/core-0-panic-ed-but-reboot-does-not-happen</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 01:24:15 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2382.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 16 Oct 2020 20:34:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core 0 panic&#x27;ed, but reboot does not happen on Thu, 12 Nov 2020 14:56:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> :</p>
<p dir="auto">So far the "80Mhz" fix is holding up since Oct-21st , running on 2 units.</p>
<p dir="auto">I will try a few more M5StickC running at 240Mhz (with exact same program and programmed from same IDE) and see if they again lock up after a few days.</p>
]]></description><link>https://community.m5stack.com/post/10720</link><guid isPermaLink="true">https://community.m5stack.com/post/10720</guid><dc:creator><![CDATA[heleb]]></dc:creator><pubDate>Thu, 12 Nov 2020 14:56:50 GMT</pubDate></item><item><title><![CDATA[Reply to Core 0 panic&#x27;ed, but reboot does not happen on Mon, 09 Nov 2020 08:07:52 GMT]]></title><description><![CDATA[<p dir="auto">We haven't encountered such situation before, trying to replicate it didn't bring any results. our all firmware is use 240MHz by default and this shouldn't cause any troubles. maybe you could check if it's related to your program or provide any details how we can try to replicate it to see what's going on?</p>
]]></description><link>https://community.m5stack.com/post/10660</link><guid isPermaLink="true">https://community.m5stack.com/post/10660</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 09 Nov 2020 08:07:52 GMT</pubDate></item><item><title><![CDATA[Reply to Core 0 panic&#x27;ed, but reboot does not happen on Sat, 07 Nov 2020 10:20:44 GMT]]></title><description><![CDATA[<p dir="auto">Reduced CPU from 240MHz to 80MHz ----Problem seems to be gone</p>
]]></description><link>https://community.m5stack.com/post/10636</link><guid isPermaLink="true">https://community.m5stack.com/post/10636</guid><dc:creator><![CDATA[heleb]]></dc:creator><pubDate>Sat, 07 Nov 2020 10:20:44 GMT</pubDate></item><item><title><![CDATA[Reply to Core 0 panic&#x27;ed, but reboot does not happen on Sat, 17 Oct 2020 12:13:57 GMT]]></title><description><![CDATA[<p dir="auto">I set CONFIG_ESP32_PANIC_SILENT_REBOOT=y<br />
in file /.arduiono15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/sdkconfig</p>
<p dir="auto">I did get the same error again, plus some unexpected debugging output<br />
After all, with CONFIG_ESP32_PANIC_SILENT_REBOOT=y , I would not expect any debugging output<br />
By the way, the problem happens with several M5Sticks..........</p>
<p dir="auto">-------------------------------------Log output  (same as last time)<br />
No/Bad response from Shelly:-1<br />
SSID:</p>
<p dir="auto">Guru Meditation Error: Core  0 panic'ed (IllegalInstruction). Exception was unhandled.<br />
Guru Meditation Error: Core  0 panic'ed (IllegalInstruction). Exception was unha        ndled.</p>
]]></description><link>https://community.m5stack.com/post/10365</link><guid isPermaLink="true">https://community.m5stack.com/post/10365</guid><dc:creator><![CDATA[heleb]]></dc:creator><pubDate>Sat, 17 Oct 2020 12:13:57 GMT</pubDate></item></channel></rss>
