<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Burner on linux mint doesn&#x27;t work]]></title><description><![CDATA[<p dir="auto">Hello,<br />
after i start to burn the UIFlow to my M5Stick Plus i obtain this errors:</p>
<h1>=====================================</h1>
<h1>Start Burn</h1>
<h1>--chip esp32 --port /dev/ttyUSB0 --baud 750000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x3ff000 /home/l0cutus/Scaricati/M5Burner/packages/fw/other/wifi.bin 0x1000 /home/l0cutus/Scaricati/M5Burner/packages/fw/stickc/UIFlow-v1.6.4-plus.bin</h1>
<p dir="auto">Traceback (most recent call last):<br />
File "/home/l0cutus/Scaricati/M5Burner/packages/tools/esptool.py", line 21, in &lt;module&gt;<br />
import argparse<br />
File "/usr/lib/python3.8/argparse.py", line 88, in &lt;module&gt;<br />
import re as _re<br />
File "/usr/lib/python3.8/re.py", line 145, in &lt;module&gt;<br />
class RegexFlag(enum.IntFlag):<br />
AttributeError: module 'enum' has no attribute 'IntFlag'<br />
Error in sys.excepthook:<br />
File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 62, in apport_excepthook<br />
if not enabled():<br />
File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 24, in enabled<br />
import re<br />
AttributeError: module 'enum' has no attribute 'IntFlag'</p>
<h1>Original exception was:<br />
AttributeError: module 'enum' has no attribute 'IntFlag'</h1>
<h1>Burn Failed</h1>
<p dir="auto">==========================================================================</p>
<p dir="auto">Any idea ?<br />
Thanks !</p>
]]></description><link>https://community.m5stack.com/topic/2397/m5burner-on-linux-mint-doesn-t-work</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 07:42:04 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2397.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 Oct 2020 22:22:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Burner on linux mint doesn&#x27;t work on Wed, 21 Oct 2020 13:15:45 GMT]]></title><description><![CDATA[<p dir="auto">GREAT! it worked thanks!</p>
]]></description><link>https://community.m5stack.com/post/10420</link><guid isPermaLink="true">https://community.m5stack.com/post/10420</guid><dc:creator><![CDATA[L0cutus]]></dc:creator><pubDate>Wed, 21 Oct 2020 13:15:45 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner on linux mint doesn&#x27;t work on Wed, 21 Oct 2020 10:56:10 GMT]]></title><description><![CDATA[<p dir="auto">Remove the <code>packages/tools/enum</code> in the M5Burner directory and try it again.</p>
]]></description><link>https://community.m5stack.com/post/10418</link><guid isPermaLink="true">https://community.m5stack.com/post/10418</guid><dc:creator><![CDATA[ozbk]]></dc:creator><pubDate>Wed, 21 Oct 2020 10:56:10 GMT</pubDate></item></channel></rss>
