<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[&quot;Error 22 bat val error&quot;]]></title><description><![CDATA[<p dir="auto">Hello. I have received a new M5StickC, and receive the error "Error 22: Bat Val Error, Check Hardware" when plugged into USB. The screen goes dark and the device powers off when unplugged from USB. I have tried leaving it to charging for hours as well as trying to BAT to GND trick, but to no avail. How should I proceed?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/topic/2399/error-22-bat-val-error</link><generator>RSS for Node</generator><lastBuildDate>Mon, 04 May 2026 16:18:55 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2399.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 Oct 2020 05:19:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to &quot;Error 22 bat val error&quot; on Fri, 29 Jan 2021 09:24:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zontex" aria-label="Profile: zontex">@<bdi>zontex</bdi></a> Thank You So Much.</p>
]]></description><link>https://community.m5stack.com/post/12147</link><guid isPermaLink="true">https://community.m5stack.com/post/12147</guid><dc:creator><![CDATA[Tyler_77]]></dc:creator><pubDate>Fri, 29 Jan 2021 09:24:57 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Error 22 bat val error&quot; on Fri, 29 Jan 2021 02:17:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tyler_77" aria-label="Profile: tyler_77">@<bdi>tyler_77</bdi></a> Hello, please contact me at <a href="mailto:roni@m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">roni@m5stack.com</a> and I'll do my best to assist you.</p>
]]></description><link>https://community.m5stack.com/post/12136</link><guid isPermaLink="true">https://community.m5stack.com/post/12136</guid><dc:creator><![CDATA[Zontex]]></dc:creator><pubDate>Fri, 29 Jan 2021 02:17:13 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Error 22 bat val error&quot; on Thu, 28 Jan 2021 07:51:54 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a><br />
I'm a seller in Thailand and now I have M5StickC about 10 Pcs.<br />
And all have the same problem is battery can't be charged and display error message "Error 22"<br />
After I've charged for all-day it still showing an error message.<br />
Or is it possible to use it while connecting the USB cable ? (don't mind about the battery)<br />
Thank You in Advance.</p>
]]></description><link>https://community.m5stack.com/post/12127</link><guid isPermaLink="true">https://community.m5stack.com/post/12127</guid><dc:creator><![CDATA[Tyler_77]]></dc:creator><pubDate>Thu, 28 Jan 2021 07:51:54 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Error 22 bat val error&quot; on Mon, 26 Oct 2020 09:22:07 GMT]]></title><description><![CDATA[<p dir="auto">Charge for a while. If this message is still prompted. Just contact our store.</p>
]]></description><link>https://community.m5stack.com/post/10461</link><guid isPermaLink="true">https://community.m5stack.com/post/10461</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 26 Oct 2020 09:22:07 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Error 22 bat val error&quot; on Sat, 24 Oct 2020 05:34:23 GMT]]></title><description><![CDATA[<p dir="auto">Thank you; I'll do that.</p>
]]></description><link>https://community.m5stack.com/post/10443</link><guid isPermaLink="true">https://community.m5stack.com/post/10443</guid><dc:creator><![CDATA[bigjohn2345]]></dc:creator><pubDate>Sat, 24 Oct 2020 05:34:23 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Error 22 bat val error&quot; on Fri, 23 Oct 2020 17:13:05 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/bigjohn2345" aria-label="Profile: bigjohn2345">@<bdi>bigjohn2345</bdi></a></p>
<p dir="auto">this error message seems to be part of the factory test. I am afraid the battery in your M5StackC got depleted so much that the voltage reading is below 3 volts and therefore the battery is considered 'dead'.</p>
<p dir="auto">I suggest you contact the shop and ask for a replacement.</p>
<p dir="auto">Felix</p>
<p dir="auto">From <code>FactoryTest.ino</code></p>
<pre><code>    float VBat = M5.Axp.GetBatVoltage();
    if ((VBat &lt; 3.0) || (VBat &gt; 4.4))
        ErrorMeg(0x22, "Bat Vol error ");
        return false;
]]></description><link>https://community.m5stack.com/post/10441</link><guid isPermaLink="true">https://community.m5stack.com/post/10441</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 23 Oct 2020 17:13:05 GMT</pubDate></item></channel></rss>
