<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to change color for RGB &quot;Set Atom Matrix&quot;?]]></title><description><![CDATA[<p dir="auto">How can I change the color when setting the atom matrix? It only shows white "pixels".<br />
<img src="https://imgpile.com/images/uAI61S.png" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Setting the color before has no impact. And I can not change the color within the block.</p>
<p dir="auto"><code>UIFlow v1.6.5</code></p>
Mike</p>
]]></description><link>https://community.m5stack.com/topic/2416/how-to-change-color-for-rgb-set-atom-matrix</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 17:14:50 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2416.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 26 Oct 2020 20:52:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to change color for RGB &quot;Set Atom Matrix&quot;? on Sun, 17 Jan 2021 21:37:31 GMT]]></title><description><![CDATA[<p dir="auto">I have the same problem using beta 1.6.6<br />
For a bit more detail, if you create a new RGB matrix flow step it works - you can check the matrix color box and then choose the color picker and then color the pixels how you like.</p>
<p dir="auto">But, if you copy a matrix flow step, the matrix color box will revert to white, and if you attempt to choose a new color for the matrix color box, it will not work, reverts to white.</p>
<p dir="auto">So the way to create an animation is to choose a new matrix flow step each time.</p>
<p dir="auto">But, it would be good to fix the bug, as creating animations, one always wants to start from the previous frame and then only adjust the pixels to change in that frame to the next.</p>
<p dir="auto">Thanks!</p>
<p dir="auto">brad</p>
]]></description><link>https://community.m5stack.com/post/11892</link><guid isPermaLink="true">https://community.m5stack.com/post/11892</guid><dc:creator><![CDATA[braddo]]></dc:creator><pubDate>Sun, 17 Jan 2021 21:37:31 GMT</pubDate></item><item><title><![CDATA[Reply to How to change color for RGB &quot;Set Atom Matrix&quot;? on Wed, 28 Oct 2020 02:33:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mb" aria-label="Profile: mb">@<bdi>mb</bdi></a> thank you feedback we will fix it later.  also, we suggest you use Chrome.</p>
]]></description><link>https://community.m5stack.com/post/10499</link><guid isPermaLink="true">https://community.m5stack.com/post/10499</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 28 Oct 2020 02:33:33 GMT</pubDate></item><item><title><![CDATA[Reply to How to change color for RGB &quot;Set Atom Matrix&quot;? on Tue, 27 Oct 2020 21:48:55 GMT]]></title><description><![CDATA[<p dir="auto">"Set atom matrix" module does not open the color picker - like "Set RGB Bar color".</p>
<p dir="auto">Tested on latest Firefox 82.0.1 and Safari 14.0 on Mac. With UIFlow V1.4.5 and V1.6.5.</p>
<p dir="auto">No error message in the JavaScript developer console.</p>
<p dir="auto">Should I officially open a bug report somewhere?</p>
]]></description><link>https://community.m5stack.com/post/10496</link><guid isPermaLink="true">https://community.m5stack.com/post/10496</guid><dc:creator><![CDATA[mb]]></dc:creator><pubDate>Tue, 27 Oct 2020 21:48:55 GMT</pubDate></item><item><title><![CDATA[Reply to How to change color for RGB &quot;Set Atom Matrix&quot;? on Tue, 27 Oct 2020 20:34:20 GMT]]></title><description><![CDATA[<p dir="auto">Hello Mike</p>
<p dir="auto">hmm, the color picker is a little popup window. Maybe try a different browser?</p>
<p dir="auto">Felix</p>
]]></description><link>https://community.m5stack.com/post/10492</link><guid isPermaLink="true">https://community.m5stack.com/post/10492</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 27 Oct 2020 20:34:20 GMT</pubDate></item><item><title><![CDATA[Reply to How to change color for RGB &quot;Set Atom Matrix&quot;? on Tue, 27 Oct 2020 20:27:54 GMT]]></title><description><![CDATA[<p dir="auto">Clicking on the small color rectangle next to "Set atom matrix" was my first intuitive action. But nothing happens. The mouse pointer is a grapping hand when hovering over it.</p>
<p dir="auto">And of course I can set the 5x5 matrix fields by click, but only toggle on and off. No color change.</p>
]]></description><link>https://community.m5stack.com/post/10490</link><guid isPermaLink="true">https://community.m5stack.com/post/10490</guid><dc:creator><![CDATA[mb]]></dc:creator><pubDate>Tue, 27 Oct 2020 20:27:54 GMT</pubDate></item><item><title><![CDATA[Reply to How to change color for RGB &quot;Set Atom Matrix&quot;? on Tue, 27 Oct 2020 20:06:07 GMT]]></title><description><![CDATA[<p dir="auto">you need to also click on the cells in the matrix block to set the colour</p>
]]></description><link>https://community.m5stack.com/post/10487</link><guid isPermaLink="true">https://community.m5stack.com/post/10487</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 27 Oct 2020 20:06:07 GMT</pubDate></item><item><title><![CDATA[Reply to How to change color for RGB &quot;Set Atom Matrix&quot;? on Tue, 27 Oct 2020 20:00:28 GMT]]></title><description><![CDATA[<p dir="auto">Hello Mike</p>
<p dir="auto">try clicking onto the little color rectangle next to the text 'Set atom matrix'. This should give you a color picker.</p>
<p dir="auto">Cheers<br />
]]></description><link>https://community.m5stack.com/post/10486</link><guid isPermaLink="true">https://community.m5stack.com/post/10486</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 27 Oct 2020 20:00:28 GMT</pubDate></item></channel></rss>
