<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RFID and Faces bottom not reading cards (but does if connected vial link wires)]]></title><description><![CDATA[<p dir="auto">HI</p>
<p dir="auto">I am following the tutorial to make a m5stack and RFID connected to a faces bottom board to arm and disarm my home assistant alarm<br />
when i connect the 2 via 3.3v gnd sda and scl with link wires it works fine, when i connect via the faces bottom the program on face boots but the cards dont get read, and dont show as attempted in the arduino serial debugger.<br />
the m5stack and rfid must be talking as the code doesn't load if it cant see the rfid board.</p>
<p dir="auto">i followed this <a href="https://www.hackster.io/remco/m5stack-alarm-panel-with-rfid-mqtt-to-home-assistant-496e01" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.hackster.io/remco/m5stack-alarm-panel-with-rfid-mqtt-to-home-assistant-496e01</a></p>
<p dir="auto">any ideas why this is happening?</p>
]]></description><link>https://community.m5stack.com/topic/2428/rfid-and-faces-bottom-not-reading-cards-but-does-if-connected-vial-link-wires</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 14:20:23 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2428.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Oct 2020 15:46:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RFID and Faces bottom not reading cards (but does if connected vial link wires) on Thu, 05 Nov 2020 15:16:59 GMT]]></title><description><![CDATA[<p dir="auto">i ran i2c scan and it showed up as 28, i will try a different base when i get home later</p>
]]></description><link>https://community.m5stack.com/post/10626</link><guid isPermaLink="true">https://community.m5stack.com/post/10626</guid><dc:creator><![CDATA[andyace]]></dc:creator><pubDate>Thu, 05 Nov 2020 15:16:59 GMT</pubDate></item><item><title><![CDATA[Reply to RFID and Faces bottom not reading cards (but does if connected vial link wires) on Thu, 05 Nov 2020 02:01:11 GMT]]></title><description><![CDATA[<p dir="auto">make sure it a reliable connection.   you could scan the I2C address to check the Face Bottom does the RFID be connected.</p>
]]></description><link>https://community.m5stack.com/post/10612</link><guid isPermaLink="true">https://community.m5stack.com/post/10612</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 05 Nov 2020 02:01:11 GMT</pubDate></item></channel></rss>
