<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can I mix M5GO and the M5Stack Power Module ?]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I'm a little bit confused about if I'm allowed to add the power module to my M5Stack Fire Core module together with the M5GO bottom module.</p>
<p dir="auto">Some docs say that it's not ok, others say, it is ok to mix power modules.</p>
<p dir="auto">Which one is correct?</p>
<p dir="auto">Thanks and greetings,</p>
<p dir="auto">Josef</p>
]]></description><link>https://community.m5stack.com/topic/2436/can-i-mix-m5go-and-the-m5stack-power-module</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 15:20:58 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2436.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 02 Nov 2020 12:59:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can I mix M5GO and the M5Stack Power Module ? on Wed, 04 Nov 2020 01:15:14 GMT]]></title><description><![CDATA[<p dir="auto">It is safe, but the battery will charge each other.</p>
]]></description><link>https://community.m5stack.com/post/10596</link><guid isPermaLink="true">https://community.m5stack.com/post/10596</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 04 Nov 2020 01:15:14 GMT</pubDate></item><item><title><![CDATA[Reply to Can I mix M5GO and the M5Stack Power Module ? on Tue, 03 Nov 2020 11:16:22 GMT]]></title><description><![CDATA[<p dir="auto">Sorry your answer is not clear to me:</p>
<p dir="auto">You say that I can mix batteries or that I'm allowed to stack a few (but not too much!) of them. That would be ok.</p>
<p dir="auto">But in the last sentence you say that it is not recommended to stack more than only one battery because of safety.</p>
<p dir="auto">That means, it is unsafe to stack batteries in the M5stack fire ?</p>
]]></description><link>https://community.m5stack.com/post/10592</link><guid isPermaLink="true">https://community.m5stack.com/post/10592</guid><dc:creator><![CDATA[jomeier]]></dc:creator><pubDate>Tue, 03 Nov 2020 11:16:22 GMT</pubDate></item><item><title><![CDATA[Reply to Can I mix M5GO and the M5Stack Power Module ? on Tue, 03 Nov 2020 09:18:33 GMT]]></title><description><![CDATA[<p dir="auto">mix them use.  the batteries will charge each other, so there will be additional consumption of battery power. It is not recommended to stack battery modules with too many layers.</p>
<p dir="auto">For safety, it is recommended only stack one 1 piece battery module would be good.</p>
]]></description><link>https://community.m5stack.com/post/10589</link><guid isPermaLink="true">https://community.m5stack.com/post/10589</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Tue, 03 Nov 2020 09:18:33 GMT</pubDate></item><item><title><![CDATA[Reply to Can I mix M5GO and the M5Stack Power Module ? on Tue, 03 Nov 2020 08:57:28 GMT]]></title><description><![CDATA[<p dir="auto">Hi.</p>
<p dir="auto">Yes I mean the battery module.</p>
<p dir="auto">It is safe to mix them? Because the M5GO Bottom has 600mAh and the battery module has 700mAh.</p>
<p dir="auto">Is it ok to mix them? There are several security hints in some web shops that point in different ways.</p>
]]></description><link>https://community.m5stack.com/post/10588</link><guid isPermaLink="true">https://community.m5stack.com/post/10588</guid><dc:creator><![CDATA[jomeier]]></dc:creator><pubDate>Tue, 03 Nov 2020 08:57:28 GMT</pubDate></item><item><title><![CDATA[Reply to Can I mix M5GO and the M5Stack Power Module ? on Tue, 03 Nov 2020 02:56:10 GMT]]></title><description><![CDATA[<p dir="auto">Power module?  you mean battery module right?   you could stack them together.   M5GO-Bottom + Battery Module + FIRE CORE.</p>
]]></description><link>https://community.m5stack.com/post/10584</link><guid isPermaLink="true">https://community.m5stack.com/post/10584</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Tue, 03 Nov 2020 02:56:10 GMT</pubDate></item></channel></rss>
