<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core basic not work with base15]]></title><description><![CDATA[<p dir="auto">Hi, I have problem with powering core from base15. 5V is present, but core doesn't work. I figured out that when 5V is present on pin 28, no 3,3V is on pin 12. When is core powered form USB. Core works (5V and 3,3V are pressent). But i can't find why 5V from base15 doesn't step down to 3,3V in core.</p>
]]></description><link>https://community.m5stack.com/topic/2442/core-basic-not-work-with-base15</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 16:07:20 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2442.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 Nov 2020 21:48:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core basic not work with base15 on Thu, 05 Nov 2020 15:10:06 GMT]]></title><description><![CDATA[<p dir="auto">I tried everything. But I found it. Pin 28 had bad contact in conector. I slightly bended pin 28 and it works!</p>
]]></description><link>https://community.m5stack.com/post/10625</link><guid isPermaLink="true">https://community.m5stack.com/post/10625</guid><dc:creator><![CDATA[silas15]]></dc:creator><pubDate>Thu, 05 Nov 2020 15:10:06 GMT</pubDate></item><item><title><![CDATA[Reply to Core basic not work with base15 on Thu, 05 Nov 2020 08:16:25 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/silas15" aria-label="Profile: silas15">@<bdi>silas15</bdi></a></p>
<p dir="auto">Sorry to hear about your troubles.</p>
<p dir="auto">I've checked with an M5Core Fire and M5Core Gray and both run from 5V provided to pin 28 (and produce 3.3V on pin 12). I don't think M5Core Basic is different in that regard, but I cannot test that myself unfortunately.</p>
<p dir="auto">Are you sure the connection between Base 15 and Core Basic is properly pushed together?</p>
]]></description><link>https://community.m5stack.com/post/10618</link><guid isPermaLink="true">https://community.m5stack.com/post/10618</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 05 Nov 2020 08:16:25 GMT</pubDate></item></channel></rss>
