<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core 0 panic&#x27;ed -- Fix by reducing CPU speed]]></title><description><![CDATA[<p dir="auto">Had "Core 0 panic'ed......" errors on various M5StickC units.</p>
<p dir="auto">Reduced CPU speed from 240MHZ to 80MHz, problem seems to be gone .......</p>
<p dir="auto">Units run cooler too (at 240MHz units were slightly warm to touch).</p>
]]></description><link>https://community.m5stack.com/topic/2446/core-0-panic-ed-fix-by-reducing-cpu-speed</link><generator>RSS for Node</generator><lastBuildDate>Mon, 04 May 2026 16:18:54 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2446.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 07 Nov 2020 10:35:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core 0 panic&#x27;ed -- Fix by reducing CPU speed on Thu, 12 Nov 2020 15:00:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> :</p>
<p dir="auto">So far the "80Mhz" fix is holding up since Oct-21st , running on 2 units.</p>
<p dir="auto">Program and IDE are the same when running at 240MHz.<br />
When the problem occurs (at 240MHz), both units lock up so bad, that they will not even reboot.</p>
<p dir="auto">I will try a few more M5StickC running at 240Mhz (with exact same program and programmed from same IDE) and see if they again lock up after a few days.</p>
]]></description><link>https://community.m5stack.com/post/10721</link><guid isPermaLink="true">https://community.m5stack.com/post/10721</guid><dc:creator><![CDATA[heleb]]></dc:creator><pubDate>Thu, 12 Nov 2020 15:00:20 GMT</pubDate></item><item><title><![CDATA[Reply to Core 0 panic&#x27;ed -- Fix by reducing CPU speed on Mon, 09 Nov 2020 07:59:52 GMT]]></title><description><![CDATA[<p dir="auto">In this situation, we haven't met.  our all firmware is used 240MHz default.  maybe you could check it does related to your program.</p>
]]></description><link>https://community.m5stack.com/post/10659</link><guid isPermaLink="true">https://community.m5stack.com/post/10659</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 09 Nov 2020 07:59:52 GMT</pubDate></item></channel></rss>
