<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 Stick C Plus and Arduino IDE - not Port visible]]></title><description><![CDATA[<p dir="auto">Hello, I'm running Mac OS Catalina 10.15.6 and I'm not able to get the serial port running with my M5 Stick C Plus and Arduino IDE. I've already installed the CP210X driver.</p>
<p dir="auto">I´ve tried it with a MS Surface PC as well - same problem. I've used the delivered USB cable, but also a different one - without success.</p>
<p dir="auto">Could it be that the device is not OK ?</p>
<p dir="auto">Thanks,<br />
Michael</p>
]]></description><link>https://community.m5stack.com/topic/2450/m5-stick-c-plus-and-arduino-ide-not-port-visible</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 12:22:58 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2450.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 08 Nov 2020 19:19:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 Stick C Plus and Arduino IDE - not Port visible on Mon, 09 Nov 2020 10:09:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi Mike! happy you solved it, would you mind sharing what driver you used? we have shared on our M5Stack documentation how to install drivers for different system, have you tried to follow that? it didn't work for you?</p>
]]></description><link>https://community.m5stack.com/post/10665</link><guid isPermaLink="true">https://community.m5stack.com/post/10665</guid><dc:creator><![CDATA[Zontex]]></dc:creator><pubDate>Mon, 09 Nov 2020 10:09:01 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Stick C Plus and Arduino IDE - not Port visible on Mon, 09 Nov 2020 10:06:54 GMT]]></title><description><![CDATA[<p dir="auto">SOLVED, I´ve tried a different driver found via Google search an now the upload works.</p>
]]></description><link>https://community.m5stack.com/post/10664</link><guid isPermaLink="true">https://community.m5stack.com/post/10664</guid><dc:creator><![CDATA[MikeMuc68]]></dc:creator><pubDate>Mon, 09 Nov 2020 10:06:54 GMT</pubDate></item></channel></rss>
