<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Blynk using UIFLow block]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I have tried to establish blynk code using UIFlow block.<br />
However, there is an error "nonetype object isn't callable"<br />
on the line "@blynk.handle_event('write v*')'.</p>
<p dir="auto">How can I solve this?</p>
from m5ui import *
from uiflow import *
from ble import blynk
setScreenColor(0x222222)
label0 = M5TextBox(13, 40, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
label1 = M5TextBox(13, 69, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
title0 = M5Title(title="Title", x=3 , fgcolor=0xFFFFFF, bgcolor=0x0000FF)
num0 = None
message = None
def blynk_write(*args):
  # global num0, message
  num0, message = args[0], args[1]
  if num0 == 15:
    label0.setText(str(message[0]))
    label1.setText(str(message[1]))
  pass
blynk.init('RoboCar', '---', blynk.BLE)
label0.setText(str(power.getBatteryLevel()))
<p dir="auto"><img src="https://pasteboard.co/JByaiUz.png" alt="Image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/2497/blynk-using-uiflow-block</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 06:38:14 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2497.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 22 Nov 2020 14:27:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Blynk using UIFLow block on Tue, 24 Nov 2020 09:42:48 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/beacon88" aria-label="Profile: beacon88">@<bdi>beacon88</bdi></a> ,<br />
Please use UiFlow online version.Offline have some bug...</p>
]]></description><link>https://community.m5stack.com/post/10849</link><guid isPermaLink="true">https://community.m5stack.com/post/10849</guid><dc:creator><![CDATA[IAMLIUBO]]></dc:creator><pubDate>Tue, 24 Nov 2020 09:42:48 GMT</pubDate></item></channel></rss>
