<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fail to burn]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have setup my new Core 2 with VSCode/PIO:</p>
<p dir="auto">MacOs Big Sur<br />
in PIO the Core 2 is configured as the following board: m5stack-core-esp32<br />
with Arduino framework and I have imported the M5Core2.h lib<br />
I can compile a simple code successfully but when I want to burn it I have the following error:<br />
Failed to write to target RAM (result was 01070000)</p>
<p dir="auto">I tried at all different speeds with 2 different usb cables.</p>
<p dir="auto">The CP21xx drivers were already installed (I am already successfully using ESP32 devkit v1 modules with the same setup) but I reinstalled them just in case....</p>
<p dir="auto">I have then tried to burn the Core2FactoryTest with the m5Burner but I end up with the same error message.</p>
<p dir="auto">Can you please help me?<br />
Thanks!<br />
Eric</p>
]]></description><link>https://community.m5stack.com/topic/2517/fail-to-burn</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 09:38:20 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2517.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 26 Nov 2020 21:09:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fail to burn on Fri, 26 Mar 2021 19:11:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/erich" aria-label="Profile: erich">@<bdi>erich</bdi></a> said in <a href="/post/13252">Fail to burn</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Honnestly I litteraly spent days trying to solve it... esp forums / github, MStack support, etc....<br />
I don't think the problem is coming from the chip, from the hours I spent reading forums and github threads it looks more like a bad implementation of python / esptool / pyserial in big sur.</p>
<p dir="auto">And yes you're right: i want to be fair here, I downgraded mainly because of this issue with my core2 but also because I had continous crashes with Safari and the system was sometimes slowing down without any reason.<br />
First time I have to downgrade an operating system...Big Sur is definitely a Big Sxxt :)</p>
<p dir="auto">I'm so distrustful of updates that I'm still on mojave!</p>
]]></description><link>https://community.m5stack.com/post/13253</link><guid isPermaLink="true">https://community.m5stack.com/post/13253</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 26 Mar 2021 19:11:13 GMT</pubDate></item><item><title><![CDATA[Reply to Fail to burn on Fri, 26 Mar 2021 19:00:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Honnestly I litteraly spent days trying to solve it... esp forums / github, MStack support, etc....<br />
]]></description><link>https://community.m5stack.com/post/13252</link><guid isPermaLink="true">https://community.m5stack.com/post/13252</guid><dc:creator><![CDATA[erich]]></dc:creator><pubDate>Fri, 26 Mar 2021 19:00:57 GMT</pubDate></item><item><title><![CDATA[Reply to Fail to burn on Fri, 26 Mar 2021 18:28:13 GMT]]></title><description><![CDATA[<p dir="auto">Did you try the cold install method to REMOVE the old driver BEFORE installing the new driver?<br />
The issue is with the SILabs chip which is tempermental at the best of times and yes as you have discovered, Big Sir is just crap.</p>
]]></description><link>https://community.m5stack.com/post/13250</link><guid isPermaLink="true">https://community.m5stack.com/post/13250</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 26 Mar 2021 18:28:13 GMT</pubDate></item><item><title><![CDATA[Reply to Fail to burn on Wed, 24 Mar 2021 19:26:56 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Mark but this is nothing to do about cables (I tried 4 or 5 different data cables).<br />
This is a known issue with Big Sur.<br />
I never got any proper feedback from M5Stack on this therefore I had to downgrade to Catalina and now all is working fine.<br />
I love M5Stack products but very disappointed about the support.<br />
Never got any follow up on this issue also I emailed them 3 or 4 times that the forum links we receive by email when subscribed are not working...never solved, never received an answer....I'm just giving up</p>
]]></description><link>https://community.m5stack.com/post/13216</link><guid isPermaLink="true">https://community.m5stack.com/post/13216</guid><dc:creator><![CDATA[erich]]></dc:creator><pubDate>Wed, 24 Mar 2021 19:26:56 GMT</pubDate></item><item><title><![CDATA[Reply to Fail to burn on Tue, 23 Mar 2021 20:31:36 GMT]]></title><description><![CDATA[<p dir="auto">Jost got the same problem. After fighting hours without any success playing with upload baud rate, frequency and all parameters under the sky, realized that the factory short USB C type cable provided with the Core2 device just works  :D</p>
<p dir="auto">Give that a try.</p>
<p dir="auto">Regards,<br />
Mark</p>
]]></description><link>https://community.m5stack.com/post/13213</link><guid isPermaLink="true">https://community.m5stack.com/post/13213</guid><dc:creator><![CDATA[drax2gma]]></dc:creator><pubDate>Tue, 23 Mar 2021 20:31:36 GMT</pubDate></item></channel></rss>
