<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[USB Device not recognised]]></title><description><![CDATA[<p dir="auto">I was able to upload sketches to it if i dropped the upload speed to 115200 and i pressed the reset button when it was uploading but now windows (windows 10) isn't recognised the unit at all. I'm using the drivers that were recommended on the getting started section.</p>
]]></description><link>https://community.m5stack.com/topic/253/usb-device-not-recognised</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 14:13:02 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/253.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 05 Jul 2018 14:42:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to USB Device not recognised on Sat, 08 Sep 2018 16:39:57 GMT]]></title><description><![CDATA[<p dir="auto">I had the same bizarre issue and I found the solution here ! Just turn the USB C plug around and it works ! Weird.</p>
]]></description><link>https://community.m5stack.com/post/1496</link><guid isPermaLink="true">https://community.m5stack.com/post/1496</guid><dc:creator><![CDATA[DrWino]]></dc:creator><pubDate>Sat, 08 Sep 2018 16:39:57 GMT</pubDate></item><item><title><![CDATA[Reply to USB Device not recognised on Wed, 01 Aug 2018 17:26:54 GMT]]></title><description><![CDATA[<p dir="auto">@kieran-osborne 在 <a href="/post/1345">USB Device not recognised</a> 中说：</p>
<p dir="auto">Wow! haha, just found the most weirdest solution,<br />
not sure if the USB port in the M5 stack is wired properly,<br />
If I turn the USB C cable around then it works, so it seems like the cable has to be a certain direction for it to work, I have even tested this with multiple cables all with the same result!, so if it's not working try rotating your cable!</p>
<p dir="auto">this doesnt always work for me and i tried another cabel</p>
]]></description><link>https://community.m5stack.com/post/1348</link><guid isPermaLink="true">https://community.m5stack.com/post/1348</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 01 Aug 2018 17:26:54 GMT</pubDate></item><item><title><![CDATA[Reply to USB Device not recognised on Wed, 01 Aug 2018 14:18:46 GMT]]></title><description><![CDATA[<p dir="auto">Wow! haha, just found the most weirdest solution,<br />
]]></description><link>https://community.m5stack.com/post/1345</link><guid isPermaLink="true">https://community.m5stack.com/post/1345</guid><dc:creator><![CDATA[kieran.osborne]]></dc:creator><pubDate>Wed, 01 Aug 2018 14:18:46 GMT</pubDate></item><item><title><![CDATA[Reply to USB Device not recognised on Wed, 01 Aug 2018 13:25:09 GMT]]></title><description><![CDATA[<p dir="auto">Having the same issue again!!<br />
I'm using a USB Device Viewer and it says:</p>
<p dir="auto">*!*ERROR:  No open pipes!</p>
<p dir="auto">===&gt;Device Descriptor&lt;===<br />
*!*ERROR:  bLength of 0 incorrect, should be 18<br />
bLength:                           0x00<br />
bDescriptorType:                   0x00<br />
bcdUSB:                          0x0000<br />
bDeviceClass:                      0x00<br />
*!*ERROR:  Device enumeration failure</p>
]]></description><link>https://community.m5stack.com/post/1343</link><guid isPermaLink="true">https://community.m5stack.com/post/1343</guid><dc:creator><![CDATA[kieran.osborne]]></dc:creator><pubDate>Wed, 01 Aug 2018 13:25:09 GMT</pubDate></item><item><title><![CDATA[Reply to USB Device not recognised on Tue, 31 Jul 2018 16:23:56 GMT]]></title><description><![CDATA[<p dir="auto">@kieran-osborne 在 <a href="/post/1333">USB Device not recognised</a> 中说：</p>
<p dir="auto">I have just tried taking the bottom section off (the section with the battery in it) and it seems to be working fine now, as soon as I put that bottom section back on it doesn't work again, so strange....</p>
<p dir="auto">Interesting, I never made that connection before.</p>
]]></description><link>https://community.m5stack.com/post/1335</link><guid isPermaLink="true">https://community.m5stack.com/post/1335</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 31 Jul 2018 16:23:56 GMT</pubDate></item><item><title><![CDATA[Reply to USB Device not recognised on Tue, 31 Jul 2018 13:44:34 GMT]]></title><description><![CDATA[<p dir="auto">I have just tried taking the bottom section off (the section with the battery in it) and it seems to be working fine now, as soon as I put that bottom section back on it doesn't work again, so strange....</p>
]]></description><link>https://community.m5stack.com/post/1333</link><guid isPermaLink="true">https://community.m5stack.com/post/1333</guid><dc:creator><![CDATA[kieran.osborne]]></dc:creator><pubDate>Tue, 31 Jul 2018 13:44:34 GMT</pubDate></item><item><title><![CDATA[Reply to USB Device not recognised on Tue, 31 Jul 2018 13:14:09 GMT]]></title><description><![CDATA[<p dir="auto">I have tried it on multiple computers and they are all coming up in device manager with "Windows has stopped this device because it has reported problems. (Code 43)</p>
]]></description><link>https://community.m5stack.com/post/1332</link><guid isPermaLink="true">https://community.m5stack.com/post/1332</guid><dc:creator><![CDATA[kieran.osborne]]></dc:creator><pubDate>Tue, 31 Jul 2018 13:14:09 GMT</pubDate></item><item><title><![CDATA[Reply to USB Device not recognised on Tue, 31 Jul 2018 12:54:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Yeah, the strange thing is that I have another device which seems to use the same driver as they had the same name in device manager, and the other device seems to work fine.</p>
]]></description><link>https://community.m5stack.com/post/1331</link><guid isPermaLink="true">https://community.m5stack.com/post/1331</guid><dc:creator><![CDATA[kieran.osborne]]></dc:creator><pubDate>Tue, 31 Jul 2018 12:54:23 GMT</pubDate></item><item><title><![CDATA[Reply to USB Device not recognised on Thu, 19 Jul 2018 16:20:43 GMT]]></title><description><![CDATA[<p dir="auto">From what I understand, it is the driver for the inbuilt adapter that causes problems.</p>
]]></description><link>https://community.m5stack.com/post/1282</link><guid isPermaLink="true">https://community.m5stack.com/post/1282</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 19 Jul 2018 16:20:43 GMT</pubDate></item><item><title><![CDATA[Reply to USB Device not recognised on Thu, 19 Jul 2018 07:57:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> I have put a 2.2uf capacitor between RST and gnd as thats what I saw in the forums, I don't have another USB adapter unfortunately.<br />
Is it the USB that is causing the issue?</p>
]]></description><link>https://community.m5stack.com/post/1279</link><guid isPermaLink="true">https://community.m5stack.com/post/1279</guid><dc:creator><![CDATA[kieran.osborne]]></dc:creator><pubDate>Thu, 19 Jul 2018 07:57:30 GMT</pubDate></item><item><title><![CDATA[Reply to USB Device not recognised on Wed, 18 Jul 2018 19:56:44 GMT]]></title><description><![CDATA[<p dir="auto">I'm getting this with Mac.<br />
My solution was the 0.1uf capacitor between RST and gnd and use a CH240 usb adapter instead of the inbuilt one.</p>
]]></description><link>https://community.m5stack.com/post/1275</link><guid isPermaLink="true">https://community.m5stack.com/post/1275</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 18 Jul 2018 19:56:44 GMT</pubDate></item><item><title><![CDATA[Reply to USB Device not recognised on Wed, 18 Jul 2018 10:38:53 GMT]]></title><description><![CDATA[<p dir="auto">Anyone know why this is happening?,<br />
I can plug it in and it works, but a little while later if I disconnect it and then reconnect it, this happens.</p>
]]></description><link>https://community.m5stack.com/post/1273</link><guid isPermaLink="true">https://community.m5stack.com/post/1273</guid><dc:creator><![CDATA[kieran.osborne]]></dc:creator><pubDate>Wed, 18 Jul 2018 10:38:53 GMT</pubDate></item></channel></rss>
