<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to connect 2 ToF Sensors to a M5Stack Fire]]></title><description><![CDATA[<p dir="auto">Is it possible to connect 2 ToF sensors to the Fire ?<br />
As far as I understand the ToF sensors have all the same I2C adress and so it is not possible to connect more than 1 sensor.<br />
Or is there a way?<br />
regards<br />
K.D.</p>
]]></description><link>https://community.m5stack.com/topic/2565/how-to-connect-2-tof-sensors-to-a-m5stack-fire</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 09:37:27 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2565.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 07 Dec 2020 14:26:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to connect 2 ToF Sensors to a M5Stack Fire on Tue, 08 Dec 2020 06:30:43 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for the answer.<br />
I will try the PaHub.</p>
<p dir="auto">K.D.</p>
]]></description><link>https://community.m5stack.com/post/11107</link><guid isPermaLink="true">https://community.m5stack.com/post/11107</guid><dc:creator><![CDATA[ramaker]]></dc:creator><pubDate>Tue, 08 Dec 2020 06:30:43 GMT</pubDate></item><item><title><![CDATA[Reply to How to connect 2 ToF Sensors to a M5Stack Fire on Mon, 07 Dec 2020 22:51:16 GMT]]></title><description><![CDATA[<p dir="auto">If you are using a Grove ToF from Seeed there are pads to add a two pin header for the Xshutdown input and Interrupt output pins.  You can use another GPIO to disable the first ToF while you program the second one to a different address.  You do have to reprogram it every time you power up.  Probably just easier to get the PaHUB.</p>
]]></description><link>https://community.m5stack.com/post/11103</link><guid isPermaLink="true">https://community.m5stack.com/post/11103</guid><dc:creator><![CDATA[ralphjy]]></dc:creator><pubDate>Mon, 07 Dec 2020 22:51:16 GMT</pubDate></item><item><title><![CDATA[Reply to How to connect 2 ToF Sensors to a M5Stack Fire on Mon, 07 Dec 2020 22:08:28 GMT]]></title><description><![CDATA[<p dir="auto">The I2C address of the VL53L0X can be changed by a software command. But this is only possible, if only one sensor is connected, because all sensors have the same address, when they are switched on.<br />
You can first connect one of the sensors and change the address of this sensor. Then you can connect the second sensor. Now you have two sensors with different addresses.<br />
Unfortunately the sensor forgets the changed address at a restart. Or more precisely, when it loses its supply voltage.<br />
I hope this helps.</p>
]]></description><link>https://community.m5stack.com/post/11102</link><guid isPermaLink="true">https://community.m5stack.com/post/11102</guid><dc:creator><![CDATA[hague]]></dc:creator><pubDate>Mon, 07 Dec 2020 22:08:28 GMT</pubDate></item><item><title><![CDATA[Reply to How to connect 2 ToF Sensors to a M5Stack Fire on Mon, 07 Dec 2020 20:09:21 GMT]]></title><description><![CDATA[<p dir="auto">There is the unit PaHUB especially for this case:</p>
<p dir="auto">"If you want connect mutiple I2C slave devices and some of them may sharing the same address, this unit can resolve I2C address conflicts."</p>
<p dir="auto"><a href="https://docs.m5stack.com/#/en/unit/pahub" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/unit/pahub</a></p>
]]></description><link>https://community.m5stack.com/post/11099</link><guid isPermaLink="true">https://community.m5stack.com/post/11099</guid><dc:creator><![CDATA[sodoku]]></dc:creator><pubDate>Mon, 07 Dec 2020 20:09:21 GMT</pubDate></item></channel></rss>
