<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to use CAN UNIT]]></title><description><![CDATA[<p dir="auto">I got a CAN UNIT that connects with the GROVE interface.<br />
When I tried the code linked below in the test, it worked on M5Stack Fire, but not on M5Stack Basic.<br />
I assigned the TX and RX settings to GROVE PORTA.<br />
It worked with this content on Fire.<br />
I also confirmed it with M5Stic-C, but it still did not work.<br />
Are there any settings that I have forgotten?</p>
<p dir="auto"><a href="https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Unit/CAN" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Unit/CAN</a></p>
]]></description><link>https://community.m5stack.com/topic/2597/how-to-use-can-unit</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 03:11:06 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2597.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Dec 2020 05:20:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to use CAN UNIT on Mon, 01 Nov 2021 09:20:54 GMT]]></title><description><![CDATA[<p dir="auto">did you have to add a terminal resistor between the H and L lines?</p>
]]></description><link>https://community.m5stack.com/post/15325</link><guid isPermaLink="true">https://community.m5stack.com/post/15325</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 01 Nov 2021 09:20:54 GMT</pubDate></item><item><title><![CDATA[Reply to How to use CAN UNIT on Sat, 30 Oct 2021 07:51:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ryokurta256" aria-label="Profile: ryokurta256">@<bdi>ryokurta256</bdi></a> Did you solve this? I'm having the same trouble with the M5Tough. It works on the Fire but not on the Tough...</p>
]]></description><link>https://community.m5stack.com/post/15297</link><guid isPermaLink="true">https://community.m5stack.com/post/15297</guid><dc:creator><![CDATA[gschora]]></dc:creator><pubDate>Sat, 30 Oct 2021 07:51:49 GMT</pubDate></item></channel></rss>
