<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[AXP192 interrupt output not used]]></title><description><![CDATA[<p dir="auto">Hi M5Stack guys</p>
<p dir="auto">looking at the M5Core2 schematic I realised that the AXP192 interrupt output is not used and not connected to any ESP32 GPIO.</p>
<p dir="auto">I am asking because M5Stick and M5Stick Plus have its AXP192 interrupt output connected to ESP32 GPIO35.</p>
<p dir="auto">What is the reason you decided not to use the AXP192 interrupt output in the M5Core2 device? Technical issue? Oversight?</p>
<p dir="auto"><img src="/assets/uploads/files/1608021171362-m5core2axp192intnotconnected.png" alt="0_1608021166629_M5Core2Axp192IntNotConnected.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/2600/axp192-interrupt-output-not-used</link><generator>RSS for Node</generator><lastBuildDate>Mon, 04 May 2026 20:48:40 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2600.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Dec 2020 08:32:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to AXP192 interrupt output not used on Thu, 17 Dec 2020 08:22:34 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/zontex" aria-label="Profile: Zontex">@<bdi>Zontex</bdi></a></p>
<p dir="auto">Understood. Thank you for checking.</p>
<p dir="auto">Maybe it could still be wired to a GPIO, but via a solder bridge, so it could be used optionally?</p>
<p dir="auto">Anyways, I've <a href="https://www.gwendesign.ch/kb/m5stack/m5core2/#axp192-interrupt-output" target="_blank" rel="noopener noreferrer nofollow ugc">soldered a wire</a> from AXP IRQ to ESP32 GPIO35. I can detect now when USB (aka ACIN) has been connected or disconnected while ESP32 is in light sleep and use that to wake up.</p>
<p dir="auto">Cheers<br />
]]></description><link>https://community.m5stack.com/post/11254</link><guid isPermaLink="true">https://community.m5stack.com/post/11254</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 17 Dec 2020 08:22:34 GMT</pubDate></item><item><title><![CDATA[Reply to AXP192 interrupt output not used on Thu, 17 Dec 2020 03:04:30 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a>, yes after asking our engineer it seems to be a hardware limitation on the new Core2 this is due to the GPIO pins from the ESP32 must be used for other purposes so couldn't be assigned to the IRQ pin.</p>
]]></description><link>https://community.m5stack.com/post/11243</link><guid isPermaLink="true">https://community.m5stack.com/post/11243</guid><dc:creator><![CDATA[Zontex]]></dc:creator><pubDate>Thu, 17 Dec 2020 03:04:30 GMT</pubDate></item></channel></rss>
